Broken chain
[Closed] Broken chain
3 Users
Why do chains break? Broke the rivet out of a SRAM 9 speed chain last night whilst trying to climb something steep. I'm not worried about it - the chain's had a good (if muddy) life. I'm just interested in the mode of failure and if there's anything I can do to reduce the risk next time.
Posted : 15/04/2010 11:45 am
keep it clean and lubed, avoid crosschaining
normally the pin twists out of the fishplate from what I can see. I've not broken one in a while that wasn't due to chainsuck twisting a link (that was a fun evening). I'd say that allowing the chain to stay dirty probably leads to wear at the pins and fishplates and eventually something gives. I take my chain off the bike to clean it in an old waterbottle with degreaser (tried petrol for a while, which worked OK but was 'orrible). Soak and shake whilst working on the rest of the bike. Test the cleanliness of the chain by grabbing a length and twisting it along its length. You will feel the grit between the plates if there's any there. clean again if needed.
Posted : 15/04/2010 12:14 pm
Dont put exccessive pressure on the chain whilst changing gear, change gear for climbs etc early.
Keep it clean and lubed as said above.
Posted : 15/04/2010 12:32 pm
