Bafang c965 spares
[Closed] Bafang c965 spares
3 Users
Anyone got a good supplier for bafang spares.
I need a remove switch for a c965 headunit . The rubber buttons on mine have given up being waterproof after 5 years use and it's now started being unresponsive in the rain.
Everyone wants to sell me a whole new LCD controller which isn't really what I want. The switch is a plug in unit so no reason it shouldn't be availible seperate that I know of
Anyone seen one ?
Posted : 08/05/2021 12:17 pm
I thought the switch was hardwired into the LCD panel. I think we got our replacement from someone on Amazon, via Hong Kong.
Posted : 08/05/2021 3:18 pm
I hope not as mines in my house on. The mantle attempting to dry it out.....and the bike/LCD unit are outside in the rain 🙂
Absolutely definantly two parts on the c965 unit . Connected by a 4 pin plug.
Posted : 08/05/2021 3:26 pm
Although you have prompted me to look closer at the current on the market at Dillinger c965 and it is indeed hard wired and a very different design .
Probably explains why I can't find them as spares.....
Wonder if any other switches will work:/
Posted : 08/05/2021 3:32 pm
Good luck with the search, if no luck I should imagine that the newer version would work so long as the connections are the same pin configuration.
Posted : 09/05/2021 1:19 am
There’s a guy on eBay selling micro switches for DI2, to put under tape etc, wonder if these would work.
Posted : 09/05/2021 9:55 am
Stripped it down.
Dried it out
Removed the green solder and resoldered the joint.
Double bagged and taped it.
Won't be hassling me for a while.
Mean while I'll look for a new one but far less of a rush now.
Posted : 10/05/2021 9:01 pm
Replaced it with a 500c. In the end.
It worked fine for a week or so then reverted to its old ways
While I was waiting on it I fitted the thumb throttle that came with the kit
When on thumb throttle it doesn't limit to 15.5.....
30mph+ with ease so I have to manually limit it....obviously it would rinse battery at 30mph.
Posted : 03/06/2021 12:33 pm
