Are we allowed to t...
[Closed] Are we allowed to talk about it now?
21 Users
Just one part of MTBing I cannot get excited about.
A 3 speed hammershimdt though, that would be progress.
Posted : 16/04/2010 8:24 am
Are comments now blocked on the STW page?
Anyway WTF is 'a more stable drivechain for any type of rider!" ?
Did it make more sense in the original German powerpoint slides 🙂
Posted : 16/04/2010 8:26 am
LOL about how it's a new system, way of shifting etc and not hjust the addition of a 10th cog.
BS!
They seem to have discontinued the SLX rear mech in GS form! That seems a bit bloody stupid.
Posted : 16/04/2010 8:27 am
Damn I was hoping for a double specific front mech.
Posted : 16/04/2010 8:29 am
This revolutionary technology not uses a 10-speed cassette, but that is not the only feature of this new system
Can't see much mention of any other new features, let alone see what's revolutionary.
as cynic-al, marketing bs.
Posted : 16/04/2010 8:30 am
Don't get what they're doing with the chainset, sticking with a triple, with the associated wider q-factor and bad chainlines, and yet narrowing the available ratios!
The Alfine 11 is about a thousand times more exciting than this announcement.
Posted : 16/04/2010 8:31 am
 nuke
I'll get it at some point as I should imagine it will become the new 'standard' but really couldn't care...I set my bikes up with the high and low gear ratios I need and having an extra gear in-between those ratios really makes no difference to me.
SHIMANO
when will you listen we DO NOT WANT closer ratios, more sprockets and a narrower chain
we WANT a MORE RELIABLE system theat allows year round round geared use through the mud. wide physical spacing, wide chain and less ratios would probably be ideal
Posted : 16/04/2010 8:42 am
Its all about performance
- Sounds like a you tube video I saw once 😉
Posted : 16/04/2010 8:44 am
I must admit at first glance they do seem to have missed the point rather!
I can't imagine they'd be that far wrong, I suspect a double chainset may still come along.
Posted : 16/04/2010 8:52 am
seriously, how do we change this? - i'm sure that some people love 9speed systems, and will love the new 10speed systems. but i would love an alternative '5-gears-nicy-and-chunky-so-they-work' system.
is this another uk-specific thing?
Posted : 16/04/2010 8:56 am
Bring back 7 speed stx rc
Posted : 16/04/2010 9:00 am
This stuff does look different to the, *ahem* covertly distributed information that was doing the rounds before.
Posted : 16/04/2010 9:04 am
So to go shimano 10 speed i would need a new cassette and rear shifter?
Lose 1 chainring upfront and go 26/38 or similar - jobs a good un?
Posted : 16/04/2010 9:09 am
And a new chain, but yes.
Posted : 16/04/2010 9:10 am
nowt to get excited about imo.
Posted : 16/04/2010 9:12 am
It does seem strange that there are no doubles and no double mechs - hopefully they'll be a second stage press release.
Posted : 16/04/2010 9:15 am
So. XTR is their cutting edge, 'for race only' gruppo where all the best of the very best stuff happens. And that's staying 9-speed. What does that say exactly?
Posted : 16/04/2010 9:17 am
They really are missing a trick if they do not release a double front mech capable of shifting over bigger rings than 36T.
Posted : 16/04/2010 9:19 am
It might say that shimano haven't announced all the new stuff yet, then again it might not 🙂
Posted : 16/04/2010 9:20 am
Why would everyone assume that because sram went 10x2 that Shimano would?
Posted : 16/04/2010 9:25 am
But 10 is one more than 9. It's one better.
Posted : 16/04/2010 9:27 am
Because it's very clearly the main benefit of going from 9 to 10 speed.
Why sell you a double this year when they can do that next year?
Posted : 16/04/2010 9:29 am
That would be the Alfine 11 speed wouldn't it?
Posted : 16/04/2010 9:32 am
clubber, I dont see why the 10 made it logical to go 2x10 when you only have the same overall spread of gears, in fact still only the same spread as 8 speed too, just slightly closer ratios.
I would like to have it explained.
Posted : 16/04/2010 9:33 am
Aaaah, I hadn't realised that xtr hadn't been released yet. Oops! Might reserve a little bickering grease for when that comes out then...
Posted : 16/04/2010 9:34 am
Average 8 speed cassette: 11-28
Average 9 speed cassette: 11-32
Average 10 speed cassette: 11-36
There were of course bigger 8 speed ones, and 11-34 9 speed ones have become more popular recently.
Going 2x8 would mean a pretty tall bottom gear, or small rings and a low top gear. The wider spread of a 10 speed 11-36 cassette means you can have a wider range of gears on a double crank without crazy intermediate jumps.
Posted : 16/04/2010 9:36 am
Actually, I 'get' the chainset.
I don't race, but like doing long days over rough terrain, often with my camping gear.
That means i appreciate lots of gears, especially low ones, and don't need the high ratio of 44x11. Using a 42 big ring also means that I'll use the big ring slightly more often, and also use it in slightly smaller sprockets, instead of just sitting in big ring/fifth sprocket like I usually do.
In theory this should actually result in slightly longer drivetrain life than I'm used to, probably not what Shimano intended! 😀
Posted : 16/04/2010 9:40 am
er fairly sure shimano already make an 11-36 9 speed cassette, I have only ever ran 11-34 (though I am going to try an 11-28 when I get chance.) I acually have felt for ages the jump in gears between 1--34 cassettes is too much for the bits n bobs of racing I do, for general riding though its fine. so closer ratios would have suited me more a 10 speed 11-34 would probably be about my ideal, wether I would drop a front ring I dont know not dabbled with that, though I did rather enjoy 1x9.
However if the 11-36 is now the new standard cassette I do see why would assume the swap to 2x10
Posted : 16/04/2010 9:46 am
They do a 12-36, consequently with bigger gaps between the rings and the loss of a top gear.
Probably doesn't matter to most, but if it does, 10 speed will solve it.
Posted : 16/04/2010 9:50 am
