Am i a twat? Thule ...
[Closed] Am i a twat? Thule 591 fitting!
Am i being stupid or something? just tried fitting the second 591 to the left side of my roofbars. You should be able to remove and rotate the front mounting plate with the securing bar from the carrier, so that it faces the other way, so making it easier to mount bikes. No problem with that, but, mounting the front plate to the roof bars the Tbar bolts are then on the wrong side of the plate and the locking handles dont fit! Anyone else had this problem?
Posted : 01/01/2010 3:24 pm
Anyone?
Posted : 02/01/2010 10:21 am
There are two sets of mounting holes in the front bracket for mounting the bike carrying rail which are only accessible when it's off the roof bars. Look at a "normal" one and use the other set of holes
I fitted mine and if I can do it anyone can ๐Ÿ˜‰
Posted : 02/01/2010 10:34 am
Do you have one fitted to both sides of your car? Do they align with each other or is one fitted forward of the other? It would work then, but one is about 15cm infront of the other!If you mount the rail on the other holes, you then have the locking leavers in the wrong side and they dont fit!
Posted : 02/01/2010 3:37 pm
Look at page 7 here:
I have 4 on a set of aerobars, so it can't be that difficult.
Posted : 02/01/2010 3:43 pm
I know it should be easy to do, but think i may be having a 'senior' moment! Going to take it back off and start again when the snow stops!
Posted : 02/01/2010 3:49 pm
mickasaki - yup, switched one of my 591s round and they are no longer symmetric on the roof - one is further forward than the other, so that the Tbar lines up with the nubbin that fits into the aerobar slot.
Also, little tip for you, on the one you swap round, the chainring of the bike will now make contact with the clamp bar, so I'd recommend shifting up the chain to big ring to stop the teeth eating into the clamp.
Posted : 02/01/2010 3:51 pm
I don't remember having any major problems fitting them to the aero bars. I have 2 x facing fwd and 2 x facing back (alternated).
Have a brew, start again ๐Ÿ™‚
Posted : 02/01/2010 3:54 pm
Do you all still have the front locking leavers coming through the base mount, in the same holes as the right carrier? Starting to wonder if they have changed the front base mount recently?
Posted : 02/01/2010 4:08 pm
Not wanting to sound like a twunt...
have you read the manual? pg 7 tells you how to do it.
PDF link on this page (under fitting instructions), if you do not have the manual: http://www.roofbox.co.uk/scripts/rbvehsel4_tab.php/car-accessories/thule_proride_aluminium_cycle_carrier_no_591/njNA_vVotQS84bRMCktLGSo.9oO2bzgo9bQdIV6t
Posted : 02/01/2010 4:19 pm
Yes i did read it! and starting to feal a twunt myself to be honest!
Posted : 02/01/2010 4:21 pm
Well, lesson learnt - dont try and adjust it to be level with the other rack, without making sure that one is right first! Thanks for the help, and yes i am a ****
Posted : 02/01/2010 4:50 pm
