Alfine Hubs
[Closed] Alfine Hubs
31 Users
Just had a search through the forum and can't find a thread asking for opinions please.
Further to my post the other day re a 1x9 setup this is another consideration for the Scandal build.
Are they any good / reliable as I believe they were designed for commuter bikes?
Is the weight noticeable?
What ratios do you run?
Anyone running 32f x 23r with a Nexus sproket?
Anyone using them for marathon events - solos etc
Thanks in advance
Posted : 22/01/2010 11:14 am
The Nexus hub was designed for commuters, the Alfine is the MTB version of it. There were a couple of threads on here when the snow was about praising their lack of clogging. Might be worth a search.
Posted : 22/01/2010 11:24 am
[URL= http://www.singletrackworld.com/forum/topic/problems-with-my-alfine-in-deep-snow ]Have a look here[/url]
Posted : 22/01/2010 11:27 am
generally mine has had most use as a commuter along muddy canal tracks, but i did do MM2009 with no problems at all (29er alfined slot dropout scandal)
running a nexus sprocket (either 18 or 20) to get a better chainline
[img] ?ver=12641596480001[/img]
[img] ?ver=12641593650001[/img]
compared to a SS, then yes the weight is noticeable - just depends if you really care about it
Posted : 22/01/2010 11:28 am
Good timing. I used mine at the strathpuffer.
[i]Are they any good / reliable as I believe they were designed for commuter bikes?[/i]
only had mine 3 months but no reliability issues and very few / none reported. I spoke to Ben @ kinetics who sells a few - he has seen no failures even with them being used on tandems.
the nexus is the commuter hub. The alfine is rated for MTBs
[i]Is the weight noticeable?[/i]
to me - when you pick the bike up yes. In riding - no. I can bunny hop it as badly as I can any bike. Teh overall weigh increase is not much - its the distribution that is very different
[i]What ratios do you run?[/i]
32 / 18 as stock. I ran 22 / 18 at the puffer. Going to 32 / 16 for commuting
[i]Anyone running 32f x 23r with a Nexus sproket?[/i]
It has been done and should be no problem. IIRC thats the lowest recommended gearing
[i]Anyone using them for marathon events - solos etc
[/i]
Quite a few alfines at the puffer - mainly on Genesis IO IDs like mine. Used as hire bikes a lot - the Hub at GT uses them and are on their second batch. I ain't a real racer tho.
Posted : 22/01/2010 11:31 am
Yep I am on a 29er. No problems with it.
Well apart from the fact that I'm not that keen on it performance wise.
Posted : 22/01/2010 11:39 am
Had one on my 29er set up for commuting-34/18 with the sprocket turned round for better chainline (remove the guide).No problems reliability wise,you have off back off a LOT to change gear and its not so much the overall weight but the fact its hung right off the back of the bike.You cant flick the back end over stuff too easily-a few people who got them suffered loads of pinch flats till they adjusted.
Posted : 22/01/2010 11:51 am
Thanks everyone for the feedback.
Probably a numpty question, but Jeremy, when you say you ran 22x18 do you mean you did 22 (f) & 18 (r)
If so, what crankset are you running and how did you do it. From my understanding, if I was to do this with an XT crankset, I would have to run the 22 ring in the granny position. Does this not screw up the chainline?
Is this easier than doing the 32 x23 thing I mentioned above, which you do remember correctly, is the recommended lowest combination?
Is it easy to change the sprocket?
Posted : 22/01/2010 12:02 pm
For sitting spinning your way through long rides Alfines are brill. But for point and squirt, dodging the trees in the woods riding they don't have the crisp pickup of a singlespeed. That's why I have two rear wheels for that bike and can swap them and fit the shifter in 15 minutes or so.
Posted : 22/01/2010 12:23 pm
hi
yes 22 front 18 rear. 22 on the granny ring position. Chainline that few mm out but I used a 9 spd chain and no issues. You can reverse the dished rear sprocket to get perfect chainline
Raceface crankset
32 / 23 would be better - you can get perfect chainline easily and 22/ 18 is ridiculously low. Think granny 1-9 with a conventional set up - I was spinning out at 15 mph or less. Being old and slow and riding the puffer I wanted really low gears.
changing the sprocket is fairly easy. remove the shifter mechanism - which just unclips and remove a big circlip and the sprocket just comes off.
Posted : 22/01/2010 12:29 pm
Thanks. This sounds like exactly what I'm looking for. Bike is being built for 24 hr solos. Like you I need to be able to have quite a bit of flexibility over gearing.
I'm built for comfort rather than speed but I go for ages... He he
Posted : 22/01/2010 12:42 pm
The beauty of the alfine for the 24 hr solos is that you have no mech to break or go out of alignment - faff free riding.
Posted : 22/01/2010 12:47 pm
I've had mine about four months now and think it's great - I got fed up with skipping gears and chainsuck during the muddy months! I use it to convert my SS for winter use. I've had no problems so far. I iniatally ran 32/16 but have now changed it to 32/18 which is much better in the claggy conditions. A mate runs a Scandal 29er with 32/23 and is very pleased with it. I don't really notice the weight when riding it, but it does feel heavy when you pick it up.
Posted : 22/01/2010 12:57 pm
Mrs F's slot dropout InBred has had one since late 2007, ridden most days sometimes on sometimes off road, and it's been flawless. We had it serviced by the very good LBS summer 09, but having taken it to pieces they said it didn't need it, just regreased, put back together and charged next to nothing.
As other people have said, yes when you pick the bike up, and the weight is all at the back, but it's not a big deal riding it. I'd have one instead of my 1x9 derailleur Summer Season if I had a frame and the money.
Mrs F runs 32/18 happily, but a friend who rides mostly on road has just swapped to 32/16 with a Nexus cog, and I think is going to want 34 or 36 at the front.
Posted : 22/01/2010 1:23 pm
The Alfine will outlive several derailleur drivetrains if you like riding in typical UK mucky conditions.
Posted : 22/01/2010 1:33 pm
I love mine. Very reliable and apart from a quick cable tension adjust I haven't touched it. I run an 18 on the back and 26/36 upfront with an alfine tensioner and a 9spd chain.
Posted : 22/01/2010 2:29 pm
How easy is it to service the alfine?
(Just had a few people with nexus hubs breaking from winter commutes!)
Some say expensive or difficult to do?
Posted : 22/01/2010 2:37 pm
I like mine. But it is weighty. I notice it on dips. The back wheel seems to 'suck' into the ground. Also the weight is postioned out the back which moves the centre of gravity back. I countered this with a set of Fox 36's.
[url] http://www.singletrackworld.com/forum/topic/bike-pictures-from-today [/url]
And you can see the weight difference between my Alfine'd and Geared HT's. The forks and tyres are a few pounds heavier on the Alfine'd bike but the other components are similar in weight. There's still an 8lbs difference in weight.
Posted : 22/01/2010 2:47 pm
Servicing is easy. Strip the gubbins out of the shell ( a few circlips and stuff) and the gear cluster comes out. It is then soaked in oil, drained and reassembled.
NO way is an alfine 8lbs heavier. I would guestimate that compared to a 1x9 its a lb or two heavier
Posted : 22/01/2010 2:55 pm
has anyone tried a gearbox bike with an Alfine, similar to the GBoxx idea with the Rolhoff?
Posted : 22/01/2010 3:05 pm
 Del
rockitman,
try searching again. as an example:
[url]= http://www.singletrackworld.com/forum/search.php?search=alfine+inbred&advanced=1&exact=1&posts=1&highlight=1&users=0&located=0&forums []=0&maxcount=100&age=999999&direction=0&sort=date[/url]
Posted : 22/01/2010 3:06 pm
TandemJeremy - Member
If the derailleur system was built to the same life expectancy as the Alfine it would weigh much more.
Posted : 22/01/2010 4:00 pm
Thanks for info TJ.
Haven't stripped an Alfine model yet.
Posted : 22/01/2010 4:04 pm
I've tried a Hammerschmidt/Alfine combo... it feels (and is) quite heavy, but the gear range is good and I didn't mind the slight drag when the front is in 'overdrive' ('big ring' equivalent). Have dropped the Alfine for now to save some weight and am running a single 16T on the back... so a 2-speed setup 🙂
Posted : 22/01/2010 4:05 pm
If you read the whole sentence you'll see that I qualified the heavier items between the bikes.
I was surprised by the difference. The forks and tyres may account for 4.5lbs. The component spec difference is at most a 1lbs but the rest is the Alfine.
Posted : 22/01/2010 4:41 pm
Either that's really badly worded or your scales are really bad.
So your trying to say the alfine weighs 5-6lb?
My whole bike is 32lb (minus 1/4 ounce) and the only light thing on there is the RC41F. THe rest is all clysedale to go with the rider, you'd have to be getting a heavyweight FS to beat mine. When riding I don't notice any weight penatly anywhere.
Edit - Ah you qualified yourself. So your saying the alfine weighs about 3.5lb... which is what it weighs... then the shifters and cables would cancel out. Your 8lb statement was very misleading.
Posted : 22/01/2010 5:18 pm
 mboy
cough* Who's the sad git that weighed his Alfine hub before building it up into a wheel to go on his bike *cough...
ME! 😆
Mine was 1668g unadorned. Which is what, just over 3.5lb iirc...
Weight difference between a derrailleur system and Alfine setup... Hmmm... Well, if you're running full XTR I think you'd probably gain 2lb or more, but if it's Deore or SLX, or even XT kit you're running, you're only going to gain 1 to 1.5lb overall.
Noticable? In a dead lift of the bike yes... When out riding? Really, it is only very slightly noticable that all that weight is in one place. Certainly my bike doesn't feel that rear heavy that it's unbalanced when its wheels leave the ground or anything.
Gear ratio wise, I was running 32x20 on my 29er, but have just bought a 22T Nexus sprocket and had a 34T chainring lying about so they've both gone on. This will only lower the gearing very slightly, approx 3% overall, but I'm hoping it will suit me. The 32x20 on a 29er at least (10% larger rolling radius on the wheels) was just slightly too tall for me... I may even end up dropping a tooth on the front perhaps and fitting a 33T ring, but the 34T is what I had lying about and the 32T ring that came off was way past its throw away date...
If you want an Alfine gearing calculator Spreadsheet that I knocked up (this applies to anyone), then email me (email is in my profile)... It's all singing, all dancing etc, and will tell you all about your overall ratios, gain ratios, gear inches, mph etc in all of the gears and for any wheel size and gearing combination.
And performance wise, well only done maybe a dozen rides on mine so far, so not quite as well placed to comment as some, but not had a single issue yet. Yes, it's a bit slower under shifting to an easier gear than a derrailleur setup (you have to back off slightly), but otherwise it's great. With my current gearing my 1st gear is the equivalent to a 22x27 derrailleur setup, and my top gear is equivalent to 32x12. So I can climb most hills without getting off and walking, and I only spin out above 20mph on the road in top.
Personally, I can't recommend them highly enough. I know a few people with them now, and everybody raves about them. It's pretty much a case of singlespeed simplicity, but with the added bonus of 8 gears rather than one. Sure, it's a bit heavier, but if you're not racing will that matter? In fact, speaking of racing, there's a guy in the US that posts on MTBR forum a lot that to prove a point, took his Alfined 29er out on one XC race instead of his normal race bike. He won funnily enough!
Oh, and the Alfine is/was a godsend through the snow and the mud. Haven't washed my bike once since I got it (about 2 months ago), gave it a mild brush down yesterday just to get the worst of the crap off prior to fitting different sprockets and a new chain. Everything just works! I was getting fed up of spending nearly as much time cleaning the drivetrains on my other bikes as I was riding them through the mud, I gave the Alfine a go. Now I doubt any of my other bikes will get a look in until the ground firms up somewhat!
Posted : 23/01/2010 3:35 pm
I've had mine on for a bit over a year now - on a Scandal. No probs at all.
Did the Kielder 100 on it and it was submerged at least three times but still absolutely fine. The advantage of being able to change gear without pedalling is surprisingly useful, especially when on a course like that when it's hard to anticipate sudden changes in direction/gradient.
I've not noticed the weight but then the Scandal was very light to begin with. The gear ratios are a bit more spread out than a derailleur, more like 8 singlespeeds slung together so that's how I ride it. I've got 34/20 which suits me fine on a 29er.
Posted : 23/01/2010 3:52 pm
 Spud
How much are you looking at for an Alfine set-up?
Posted : 23/01/2010 4:20 pm
£200 or a bit more depending.
Posted : 23/01/2010 4:22 pm
 mboy
Hub is currently £154 at CRC, cheapest I've seen
Shifter is £27 from CRC
Cog is £5-8, shop around
Fitting kit generally £10
So about £200, plus the cost of a rim, spokes and getting the wheel built...
Or hang around on ebay looking for a bargain, you may or may not be lucky. Have seen a whole setup (including built wheel) for for as little as £125, or as much as £225 on ebay...
Posted : 23/01/2010 6:55 pm
Another question - What kind of chain / chainrings do you run? Do your run singlespeed chains? Do you need a chain tensioner if not slot dropout?
Thanks
Posted : 25/01/2010 8:59 am
I am running unramped chainrings and a nine speed chain - purely so that I can use the same sram links and keep everything compatible with my other bikes. Singlespeed chain might be better considered in isolation. You need some method of adjusting the chain, EBB, slot dropouts or a tensioner
Posted : 25/01/2010 10:13 am
rode one yesterday on a fifty k loop on a scandal 29er borrowed from a mate and i thought it was awful, very clunky, having to back off the power loads when trying to climb and the gear ratio's weren't right for me.
i'll be sticking with a regular mech , casette, shifters, etc.
my mates bike has gripshift which i also found really uncomfortable, can you run a normal trigger shifter?
Posted : 25/01/2010 10:49 am
Yes you can run a rapidfire shifter, Alfine is usually supplied this way. I reckon he was running a Nexus shifter on his bike.
Posted : 25/01/2010 10:57 am
correct, he's using a nexus shifter
Posted : 25/01/2010 11:16 am
Would that be why it was so clunky?
Posted : 25/01/2010 11:32 am
no the shifter worked fine but it was just really uncomfortable for me(i feel like i have rsi a day later in my thumb and wrist, which is why i was asking about rapidfire shifters), it was the hub itself that gave the cluncky feel and sound when changing gear ratio.
to me, i felt it was just a poormans rohloff, which i accept there is around a £1000 difference.
Posted : 25/01/2010 11:38 am
Out on interest exactly how much abuse would you think an Alfine capable of withstanding.
Fed up on having no working gears on my DH bike...
Posted : 25/01/2010 11:42 am
If we dare ask what's the conclusion of the 'premier' only comparison between the Alfine and Rolly?
http://www.singletrackworld.com/2010/01/alfine-vs-rohloff-premier-content/
Posted : 25/01/2010 11:44 am
Anyone know of someone in the Manchester area who might let me have a quick blast on one (5 minutes)? I was completely sold on the idea but Flatfish's comments have concerned me. Really don't want to drop £200 on one and then not like it and have to get the whole wheel rebuilt and buy a Hope hub!
Posted : 25/01/2010 11:49 am
i'm not tryin to put you off but i'm reviewing it from a outsiders point of view, you know how it is, nobody will ever admit they bought a dog of a bike/car/hub/etc.
all i'm saying is it's not for me so i'll stick with regular gears which i admit get clogged with mud and wear a lot quicker.
Posted : 25/01/2010 11:58 am
I can understand flatfishes concerns - For me the advantages outweigh the disadvantages for some types of riding. for a 24 hr enduro bike for a non racer such as me they are great. The fixed chainline / chain centres and lack of maintenance / missed shifts outweigh the slightly sluggish shif tand th3 non even gear spread.
If you buy one and don't like it they have a high resale value.
Posted : 25/01/2010 12:08 pm
 mboy
Regarding the issue with the hub not liking to change to an easier gear under load... You quickly adapt a better technique, changing to an easier gear slightly before you need it. Anyone remember 10-15 years ago before derailleur setups were quite so advanced and would readily shift gear under load? We all had to back off to enable them to shift then... Wouldn't say it's an issue at all personally, I just look a bit further down the terrain and assess what gear I'm likely to need before I come to a climb/obstacle. The massive benefit of being able to shift gears when stationary, should you say get stuck on a climb and have to restart, is ace though!
The spread of gears is a little wide if you're used to a 9spd cassette. It's not horrendous though. Most gears are fairly well spaced, there are 2 quite big jumps though. These being between 1st and 2nd gears, and again between 5th and 6th. Personally I don't find this an issue. With the gearing that I've got on my bike, the 5th to 6th jump is fairly irrelevant, because I'm generally only using 6th 7th and 8th gears either on road or on anything pointing downwards. So I'm getting some gravity or terrain related assistance. 2nd to 5th are well spaced, and it's these gears I use most of the time offroad. The 1st to 2nd jump isn't massive though, only slightly more pronounced than going from 1st to 2nd on "normal" 11-32T cassette. No real biggie, first is primarily a bail out gear anyway, so the fact it's a lot easier is actually a positive for many.
Best way to think about it is like this... Are you the kind of rider that regularly uses all 27 gears on his MTB and values having a gear to keep the correct cadence for every situation and doesn't mind a fair bit of maintenance to keep everything working just so in the British Mud? Or are you the kind of rider that has questioned the need for a big ring on his MTB (or possibly already removed it), and also rarely uses the largest cog on the cassette on his current bike, and is fed up with maintaining a derailleur system in the British Mud?
If you're the former, don't bother, Alfine will not be for you... If like many of us you're the latter, an Alfine is quite probably going to seriously impress you. People have said to "think of it as a SingleSpeed with 8 gears" rather than think like it's a geared bike. Not sure if this is true or not, as I do actually still tend to change gear quite a bit on mine. But I've had a couple of DH bikes in the past, with a single 36 or 28T chainring up front, and an 11-32T cassette out back, and used to amaze myself how much I could actually ride if forced to get out of the saddle and honk a bit more when it came to the climbs. So a single ring with only 8/9 gears is quite "normal" for me anyway... The fact that one of my bikes has a full 27 speed setup is only because that's the one that gets used if I know that the ride will involve a combination of very steep climbs and/or lots of on-road sections where I will benefit a lot from the higher gearing. Rest of the time I make do with 2 rings and a bash, or a single ring.
Oh and as TJ says, they have a high resale value and are always in demand. Don't like it once you've tried it, you won't lose much money selling it on...
Posted : 25/01/2010 12:44 pm
Thanks Maverick Boy. I think I'll give one a whirl.
I very rarely use the big chainring, however I do use the largest cog on the cassette, but I think sometimes that just psycological. I could always adjust the gearing though to suit. The other thing is I only ride full suss bikes at the moment, both of which are "sit down and pedal" bikes (Yeti & Commencal). This will be for a Scandal build and if my memory serves me correctly you can get out of the saddle a bit more on a hardtail.
The more I think about it the less the shifting will be a problem. I grew up on a late 80's Rockhopper. As you said, you selected your gear before the climb and then accepted you weren't going to be able to change without backing off. I do change gear a lot nowadays though. But said by previous poster - it's 8 singlespeeds, shouldn't take much getting used to.
I'm building the bike primarily for a couple of solos later in the year. I won't be "racing" so to speak, just plodding around in circles for 24 hours. Potential of ripping the mech off / getting continually caked in mud etc is far worse than not so slick shifting.
Right, that will do it then. Alfine here we come... Now, what wheels do we need?
Posted : 25/01/2010 1:24 pm
 mboy
26" or 29er?
Ooops, that was meant to say "36T or 38T"
Oh, the shifting is slick enough alright... No clunks, thumps or anything, unlike a derailleur setup. It just doesn't like changing to an easier gear under too much load. Which in reality is much better long term than a derailleur setup that will change to an easier gear under a lot of load, with lots of crunching, ultimately wearing your cassette away quite quickly. Even on my derailleured bikes, I've always been the kind of person to be as kind as I possibly can to the gears in use, and try to pre-shift to an easier gear before I might need it. XT cassettes ain't cheap after all!
You could. Tandem Jeremy recently ran 22T up front with an 18T cog iirc. Wouldn't recommend that personally, it's outside of Shimano's recommended gearing range (based upon the torque load the clutch in the hub is rated for), but by the sounds of things he didn't kill it. Gave him the equivalent of just the granny ring with an 11-34T cassette!
I'm running 34/22 on my 29er, gives me the equivalent bottom gear of 22T chainring with 27T cog, and equivalent top gear of 32T chainring with 12T cog on the back. So compared to a dual ring setup, I'm missing the very bottom gear, and the very top gear essentially. Compared to a 3 ring setup I'm only missing the very bottom gear, and the three tallest gears in the largest chainring... So in reality my current gear ratio covers about 95% of my normal riding... I just have to get out the saddle a bit more on a couple of climbs, and coast a bit on fast DH onroad sections...
Posted : 25/01/2010 2:15 pm
 mboy
Just seen on your other thread that you're 6ft 6 and 18 stone...
In which case, DEFINITELY do not go out of the Shimano recommended gearing range (of which lowest recommended is 32/20 or equivalent iirc) as at your size you're likely to put a lot more torque through the clutch than me at a tad shy of 12 stone...
Posted : 25/01/2010 3:05 pm
People with Alfine set ups where have you place the shifter on the bar, has anyone managed to squeeze it between the brake lever and the grip?
I ask as when I rode a Charge Duster 8 last year I found that I had to move my hand from the most natural position on the grips (i.e. where I could brake) to downshift. This was with the shifter inside of the brake lever.
Posted : 25/01/2010 3:09 pm
 mboy
Due to the design of the Alfine shifter, there's no way it will fit outside of the brake lever sadly...
You're more than welcome to pop round and try it on my 29er though if you want mate...
You get your Tricross sorted incindentally?
Posted : 25/01/2010 3:12 pm
Can I just echo what maverick boy said - ! went very low on the gearing but I knew I wan't going to be really mashing the gears and I am 12.5 stone. It was very silly tho - spinning away at 3 mph and spinning out at 14 mphish
32/20 will give you a reasonably low gear and I thought you could go to 32/23 which gives a fairly low gear. rear sprockets are fairly cheap to experiment with as well. £5 or so IIRC
Edit - if you take the indicator off the shifter you can fir it between lever and grip or use the nexus twistie
Posted : 25/01/2010 3:18 pm
I do want to have a spin on your 29er at some point, the question was purely just curiosity.
No to the tricross, going to take it to the shop at some point this week.
Posted : 25/01/2010 3:21 pm
Saccades - Member
No, I am saying the Alfine set-up is about 2.5lbs heavier. Read the post properly.
I agree that saying 'There's about 8lbs difference between the bikes although the heavier forks and tyres will account for part of it.' But 'very misleading'? No.
Posted : 25/01/2010 3:58 pm
mk1 fan - its a lot less than that. The hub weighs 3.5lbs. You have to take the weight of a standard hub, casette, mech, off from that.
Shimano deore hub - thata 400+ g or so I believe plus a cassette - deore is 350 grammes = a mech - 300 g - call over a kg. alfine complete ( I am discounting the cables and lever as both set ups ancd comparing 1x8 with the alfine) 1.6 kilos - so its 600 grammes ish - call it a lb and a half.
Posted : 25/01/2010 4:15 pm
TJ,
You're just wrong. The frames weigh similar, the heavier components are accounted for, the remaining weight difference is all down to the Alfine. If the scales are wrong they'd be wrong on both of them.
I'm not running bottom spec components which would weigh nearer to the Alfine.
I'm really happy with my Alfine but it is heavier and more than you're quoting.
Posted : 25/01/2010 4:22 pm
Mk 1 fan - go look at weight weenies. someone on here weighed their hub at 1.6 kgs - thats 3.5 lbs. Are you telling me that your 1x9 dérailleur set up weighed a lb? According to weightweenies its nearer 2.5 lb for deore 1x9
Did you forget to include the weight of the hub?
where are my figures wrong?
Sorry - its you who has miscalculated - you simply cannot get a cassette, rear hub, QR and mech for onepound in weight.
Posted : 25/01/2010 4:28 pm
Alfine hub - 1600g
Alfine sprocket - 50g
XT M772 medium cage mech - 227g
XT 11-34 cassette - 300g
XT M775 disc hub - 411g
That in my book means the Alfine set up is 700g heavier than an XT rear end. Of course I am ignoring the fact you lose the weight of a LH shifter and a front mech.
Posted : 25/01/2010 4:35 pm
And of course you use shorter spokes with an Alfine hub so there is a few grams saved too 😛
Posted : 25/01/2010 4:36 pm
seems about right to me Mister P. I got 600 grammes on the back of a fag packet. Now way is it 1,2 kg
Posted : 25/01/2010 4:38 pm
What are you talking about?
I've broken down the weight differences between the bikes already and the result is the Alfine set up adds about 2.5lbs to my bike set up.
Again, I don't see why you're mentioning Deore (which would reduce the weight difference). I've said that bottom / entry range components haven't been used.
Posted : 25/01/2010 4:39 pm
Hence why my figures are for XT V Alfine.
Posted : 25/01/2010 4:42 pm
I was typing whilst you were posting.
The situation is that on my bike set up the Alfine adds about 2.5lbs to the overall weight.
Deal with it ladies and move on.
Posted : 25/01/2010 4:46 pm
F*Ck the weight, has anyone tried to use one for DH? Will it just explode. Im sure this a more important question!
Posted : 25/01/2010 4:59 pm
One of the guys here ran one on a Dialled Bikes Alpine last season in the Alps.
Seen a few used and abused but not for DH. I did drops and jumps on mine contrary to Shimano's guidance for the last 14-months and there was no damage when it was serviced. I'm not light at 15-stone plus in my kit.
Although, I have read threads where they've imploded being used on a commuter.
Posted : 25/01/2010 5:05 pm
Mk1 fan - sorry you are clearly wrong. I don'yt know waht 1x9 set up including a hub you can get that weighs under a lb. Go look at MrPs figures.
Posted : 25/01/2010 5:09 pm
TJ,
I reitterate -
Posted : 25/01/2010 5:18 pm
I'm really tempted by the io id, Genesis
http://www.genesisbikes.co.uk/bikes/mountain/io-ioid/
Could you live with this as your only mountain bike? (within the normal constraints of a 100mm travel hardtail)
I'd gear it right down I think, I just don't seem to use high gears that often off road
Does the hub feel good pedalling in a gear. Or is it a bit soggy and ineffiecient feeling?
Posted : 25/01/2010 5:40 pm
How can it? Simply impossible old chap - the hub weighs 3.5 lbs and the components it replaces weigh 2 lb .
You have missed something out. You simply are wrong. Arithmetic does not lie.
Posted : 25/01/2010 5:43 pm
ampthill - I like it but it but the lack of range of gears is a bit of a shortcoming when I am used to 2x9 and you get 1x9 with the alfines.
I know that the hub at glentress hs then as hire bikes and I guess other places do as well if you want to try them out.
Posted : 25/01/2010 5:45 pm
I've heard the 32:20 min gear ratio thing loads of times, can anyone point me in the direction of an official Shimano document that sets this lower limit, the only time I've read this is in reviews and on forums. I currently run 32:20 but in the past I've happily stood on the pedals with 32:22.
Posted : 25/01/2010 6:32 pm
[url=
my alfine [/url]heres a pi
Posted : 25/01/2010 6:40 pm
I have not been able to find one nor any indication of one and my understanding was that 32/23 was the lowest allowable. My 22/18 is well lower than that. I didn't stand on the pedals tho
Posted : 25/01/2010 6:41 pm
i work in a shop and we have an Alfine built into a black 317 as in my previous pic, not the same but another one for sale including shifter fitting kit and cog for £225. if your iunterested let me know.
Posted : 25/01/2010 6:43 pm
Someone remind me and I will look into the min/max sprocket size at work in the morning.
Posted : 25/01/2010 7:36 pm
Sadly having done the maths I don't think the range is quite big enough for me. This is due to my desire for a lowest gear of 22 30 equivilant.
Oh well its a great concept.....
Posted : 25/01/2010 9:00 pm
ampthill - alfine on 32 / 23 gearing give a bottom gear of 22 / 30 equivalent with a top gear of 32 /14 equivalent. according to the fine calculator some chap whose name I forgot gave me.
Posted : 25/01/2010 9:17 pm
 mboy
I was curious! 😳
OK, this time I was bored and curious! 😳
Can't remember who/where it was, but I spoke to someone about this who had already enquired via Shimano about this... Basically, anything down to 32/20 is deemed as ok, anything lower and don't expect to be able to warranty it if anything goes wrong... If they can of course prove it. I don't think it's a set in stone thing, more of a min. recommendation that they go by, rather than using a min. weight limit. Of course, they could go the other way and say that you are free to use whatever gearing you want, but nobody over 10 stone can ride one...
One guy in the states was running a 26/22 setup on his apparently. At 18 stone and riding big hills all day, he managed to strip the clutches on his, which is the torque related issue that Shimano are warning against. To be fair though, I think (can't be 100% sure) he got it fixed under warranty. But of course he had to send it back, and that's a load of hassle etc.
Think of it more like this... At 18 stone would you run a set of coil sprung forks with the Standard Medium strength Spring, or would you buy the Extra Firm spring before riding it? At 12st I can get away with the medium, and won't kill my forks, but if I were 18st I'm going to exert a lot more force on it. Rockshox isn't saying they wouldn't fix my fork if I ran it undersprung, but you could pretty much guarantee I'd bugger it up in a short space of time if it was that severely undersprung if you get my drift...
So my advice based on that is if you're a big guy, don't expect to be able to gear it down that much... If you're similar weight to myself, you can probably get away with doing what TJ did and running a 22T up front if you so desire...
Using a 34/22 on mine gives me an equivalent bottom gear of 22/27... Was worried it'd kill me, but honestly, it's like 1 gear difference on a 9spd cassette... Try it, it'll put hairs on your chest if nothing else! 😉
VERY direct, not at all mushy. I've ridden plenty of freehubs on "normal" hubs before that are a lot less direct and feel mushy in comparison.
Again, anyone else wants the gear calculator spreadsheet, just email me... Email is in my profile...
Posted : 25/01/2010 9:59 pm
I normally run single speed 32/18 on my 29er but round these parts are very hilly and you get no rest when your out with a group so i took a punt and bought a built alfine wheel running it the same 32/18 set up.yes you have to back of for it change gear sometimes if under load but it aint that bad. I tend to just keep it in 4th and only use other gears on killer hills or fast road keeping up.
Recommended? yes.
Posted : 25/01/2010 10:12 pm
surely it's a power rather than a weight issue?
you might be a hefty chap but have weedy legs??
Posted : 25/01/2010 10:38 pm
It's weight AND power. Lots of power but little weight would be fine and lots of weight but little power ditto. Heavy riders with lots of power will be really bad (that's me then!). Typically though bigger guys will be more powerful though their power to weight ratio will be lower which makes them less good at hill climbing.
Posted : 25/01/2010 10:46 pm
 mboy
It's a torque issue, not power...
Torque kills gearboxs and clutches (which is what the Alfine is) not Power...
A Big heavy guy is going to exert a lot more toque on the hub than a much smaller guy, simply by standing on the pedals! OK, Lance Armstrong might exert even more torque again still by being a superhuman with an incredibly efficient pedalling technique, but none of us are that I suspect!
Power = Torque x (Rotational) Speed
Remember that!
So Power is kind of irrelevant if the speed is increased. A Big Guy churning the pedals at 50rpm but applying 100Nm of torque is producing the same Power as a small guy spinning the pedals at 100rpm but only applying 50Nm of torque.
The Big Guy is going to kill/wear out things much faster though!
Posted : 25/01/2010 10:53 pm
