Hi
I was fitting a front guard onto my Fox 36 Float Factory Fork.
When I removed the air bleed valve I lost some oil from the fork in error. Probably about a circumference of a golf ball worth of oil.
Do I add Fox 20wt Gold oil back into the air bleed valve?
Thanks
Posted : 25/05/2025 7:16 pm
I would. Either via the foot nut, or the hole it came out of
Posted : 25/05/2025 7:23 pm
Depends on the damper and which side it is. One side uses Fox gold, the other uses damper fluid.
Posted : 25/05/2025 7:25 pm
I would say no, it's probably overfilled anyway.
You might get a tiny bit out that's collected around the valve as it's run down but not the amount you describe.
Posted : 25/05/2025 9:15 pm
