2014 rockshox pike ...
[Closed] 2014 rockshox pike problems/advice
Got some pikes a few months ago and loved them, (160mm RT3 ) riding today and they didn't feel right but couldn't put my finger on the reason, happened to look at the sag indicator when I was off the bike and the fork is sat into 20mm of travel with no load on it???
I had fox forks do something similar years ago so I emptied all the air, compressed the fork completely and pumped up to 80 psi and tried and still sat into near 20mm!!! I can hold the lower legs and pull up on the bars and extend the travel to 160mm but a "vacuum" type feeling pulls them back into the travel!!! Any ideas before I send them off for repair.
Thanks for anything constructive.
Posted : 23/03/2014 3:38 pm
 LoCo
Negative chamber transfer port blocked not allowing the chambers to equalise.
Strip, clean & regrease should sort it or return for warranty repair to retailer
Posted : 23/03/2014 3:40 pm
Cheers loco , it may be quicker if I just sent them to you and paid , any idea how much and who to post them with???
Posted : 23/03/2014 3:46 pm
 LoCo
Hermes, insured to value, seems to the favourite with customers at the moment
Posted : 23/03/2014 3:49 pm
Any idea how much? Will help me decide regards warranty route? Thanks
Posted : 23/03/2014 3:52 pm
I had the same thing happen with my pikes, pumped them up to the max limit (150psi IIRC?) and cycled it a few times and it went up to 160mm travel again, Let the air down and it's been fine for a couple of months now.
Posted : 23/03/2014 4:10 pm
 LoCo
Yep try that first ^.
You'd be looking £20 labour plus return postage as the it'd be a lower service as well as the air spring strip
Posted : 23/03/2014 4:36 pm
Thanks guys will try that and if not will be in the post Tuesday to loco!!!
Posted : 23/03/2014 4:40 pm
Gutted!!! tried taking the pressure up to 140 psi, got full travel. Ridden round a bit let the pressure back down to 75psi back into 20% sag!!!
Posted : 23/03/2014 5:02 pm
Try it a few times it had this on my revs too, and also pull at the lowers with no air at all in, it helped mine release the negative pressure in the lowers, just basically empty the air and pull as hard as you can at the lowers, worked for me
Mine were absolutly fine after that I don't think you'll need to send them in have a play with them
Posted : 23/03/2014 7:22 pm
Thanks will try tomorrow
Posted : 23/03/2014 10:07 pm
My revs did the same. Turn them upside down and undo the nut from the airside leg. You'll see a valve. This is the negative chamber I believe. Depress the valve and release the air just watch for oil.
By no means a cure for any blockages but did this to mine and they've been fine since.
Did a strip and clean on the wife's revs with same problem And they've been good too.
Posted : 23/03/2014 11:40 pm
Thanks again
Posted : 24/03/2014 7:19 am
Do NOT do willy's suggestion.
The Pike is different the neg chamber is the lower part of the air damper on the air side.
Posted : 24/03/2014 9:45 am
Ok I've not tried it yet anyway. Cheers
I'll get them off and send them away this week, not great only 10 ish rides old
Posted : 24/03/2014 10:05 am
Mine did the same and I spoke to loco.
His suggestion was to ride it hard.
(I have changed the air damper and had grease in the port).
Ran hard down the final descent of the blade.
It fixed it.
Posted : 24/03/2014 11:02 am
I've e mailed rockshox who said try letting the air out and pulling hard up on the bars whilst hold down the legs until it lets the pressure equilize.
Posted : 24/03/2014 2:02 pm
Got the same problem with mine 🙁 started when I was playing with the bottomless tokens. My LBS has contacted Rockshox who suggested letting all the air out then pushing the fork to the bottom of it's travel, partially filling with air and cycling the fork through it's travel a few times then pumping up to the correct pressure.No joy, also pumped it up to 150 psi and cycled it up and down with no joy. It's with my LBS at the mo for a strip down as per LoCo's advice. If they can't sort it it's off to see Simon at LoCo as I need the bike for a foreign trip early next week.
Posted : 24/03/2014 2:48 pm
I'm going Spain in a 8 weeks and my concern is it happening again
Posted : 24/03/2014 3:17 pm
If it's just the port being blocked with grease and hard riding clears it then it sounds like people need to grow a set 😉
Posted : 24/03/2014 4:13 pm
had similar with my 2013 Reba's. LBS sent them back and all fine since. I had tried all of the above suggestions (apart from taking things apart) first, to no avail. Took in to LBS on a Monday, had them back Thu, and done under warranty
Posted : 24/03/2014 4:22 pm
Well it seems the problem is grease in a groove in the internals and not a blocked hole as such. Sorted and ready to collect tomorrow. LBS got the info from Rockshox to sort it. Result
Posted : 24/03/2014 6:17 pm
Sorry but unless I'm mistaken there is no groove inside and they aren't being totally honest.
I've stripped my air damper and negative side while changing my damper rod.
The air damper slides inside a tube which has no groove in it.
Loco will confirm if I'm wrong.
Posted : 24/03/2014 8:23 pm
Only what my LBS said, will see tomorrow if its sorted. Otherwise it's a trip to Wales and LoCo for me
Posted : 24/03/2014 8:32 pm
Stripping mine off tonight, sram/fishers keep telling me to get me LBS to strip them it's easy!!!
My reply was "if they damage something will it still be warranty " and they have now stopped reply to my e mails.
Posted : 24/03/2014 8:36 pm
Fozzybear you are wrong I'm afraid. It will have a dimple like this in it:
Posted : 25/03/2014 12:25 am
That's the port that fills the neg chamber.
Suppose it could be a dimple or a groove.
Posted : 25/03/2014 7:09 am
Well at least it's a simple fix. Cheers for the info Rick 8)
Posted : 25/03/2014 8:00 am
Update!!! Sram/rockshox have requested the forks back to investigate so back to fishers for repair.
Posted : 25/03/2014 1:59 pm
Picked the bike up this morning, set the sag to 30%. Back to normal. Thanks to James at my LBS and Sram/rockshox/Fishers for their technical input. How long will you be without your forks Chris? Hope all goes well with your repair.
Posted : 25/03/2014 2:31 pm
LBS say sram/fisher warrenty is fantastic so should be turned around in a week. Not sure why but sram wanted to see the fault and asked LBS no to investigate. Strange as ^ Dave had his repaired with sram advice???
Posted : 25/03/2014 6:30 pm
LBS were great for me,as @ Rick says sorted the problem. Bought motorcycles off them for ever. They started selling bicycles a few years ago. Same professional attitude. Love Em 😆
Posted : 25/03/2014 8:37 pm
I had the exact same problem with my RockShox PIKE RCT3 Solo Air 2014 (160 mm, 26"), it went down to 20% sag with no load. I tried pulling the front wheel with no air in the fork, and tried cycling the fork with 140 PSI. No luck with any of those, but after [b]pulling the wheel with 140 PSI[/b] I heard a whistling sound, and the fork became fully extended. After setting the pressure back to 75 PSI the problem was solved.
Thanks a lot for all the advice in this post!
Posted : 03/04/2014 9:13 pm
 Si
Thread revival.... Same problem tonight on a set of 150mm RCT3. Anyone have a step by step guide to cleaning said port if all the other suggestions fail!?
Posted : 15/07/2014 10:38 pm
Kind of same problem for my 160mm Pike Solo Air. Bought it a month ago from Germany and from the beginning the air pressure i used to get a sag around 25% was way off the one recommended by RS. Geared up i weigh 190lbs and the recommended psi for my weight is 80-85. Yet, i go down as much as 50 psi to get 25% sag. After cycling the fork at different pressures, even going up to 150 psi with no luck, i decided to open clean and rebuild the air spring. Needless to say that there was way too much red lube in there. After cleaning and regreasing i pressurised at 30psi, cycled the fork and i got the characteristic psssst sound of equalization. So i guess the dimple is now open (if it ever was blocked). But if i run the fork at 80 psi (recommended one) the fork feels like a pongo stick. There is no way i can run it at this pressure and get even 80% of the travel. Not to mention that the small bump sensitivity is absolutely absent (weird for a fork known for its suppleness). When i ran it at 50 psi i can get almost full travel but then again i dont feel like the fork is as supple as it should... Could the RS pressure table printed on the lower be that way off/wrong (30 psi for me)? Is there a possibility that an overdamped Charger Damper could be the reason for this? I think i have done everything i could (in regards to the air spring side) to resolve this but i have no luck.. Does any of you experienced guys have any idea what to do next?
Posted : 20/07/2014 2:00 am
@Stamion
Could just be your pressure gauge is faulty, can you verify your gauges accuracy, got another you could try?
Posted : 20/07/2014 2:15 am
Dirtydog i got two pumps,same numbers from both..
Posted : 20/07/2014 2:18 am
Hmmm.... I think I have the same problem.
Brand new Rev 120mm (29er) SoloAir.
With no air in, it's sat right down in its travel. As I add air the fork extends. By the time I get to the recommended pressure for my weight it's at about 105mm. Add a bit more air and it goes right out to 120mm.
Reading some of the advice above, I reckon this port/groove/thingy is blocked. I'll try cycling it a few times with and without air in it. If that doesn't work I'll put enough air in to get full travel and go for a ride. If [u]that[/u] doesn't work I'll send them back for repair.
Posted : 20/07/2014 8:30 am
^^ Have you got any bottomless tokens in? They reduce the airspace so you would need less pressure. My Pikes have failed again and have been at Fishers for nearly three weeks 🙄 Hope they will be back this week, had the use of a demo Orange 5 RS and the pikes on that don't work as they should.The open ,locked and pedal on the right fork leg does nothing at all. Never had a problem with my flexy Fox forks. Been looking at an Avalanche upgrade for the forks,all new internals.
Posted : 20/07/2014 8:35 am
That's marvellous I've just pulled the pin on a set of 160 dual positions from Tf Tuned I hope it's not that common a fault 🙁
Posted : 20/07/2014 10:07 am
Don't TF strip/check/fettle all the stuff they sell before they ship it out? Could have been a very wise move buying from TF...
Posted : 20/07/2014 10:10 am
No tokens for me
Posted : 20/07/2014 11:44 am
stamion...
I have the exact sample problem... did you get a solution to this??
dan
Posted : 29/08/2014 8:43 pm
 hora
stamion did you sort it?
Posted : 15/09/2014 11:47 am
 wl
Apologies for slight hijack but is there any discernible difference in performance between the basic RC model and the posher ones? I've heard differing reports. And do the Pikes generally benefit from bedding in or is out-of-the-box as good as they get? Ta.
Posted : 15/09/2014 12:24 pm
 poah
no, the only difference is in the RC you don;t have the pedal setting only open and lock.
Posted : 15/09/2014 4:45 pm
Not quite; it's got eight or so steps of adjustable LSC damping between open and locked.
I've heard some (or maybe just one) claim that they could tell the difference between their RCT3 and RC but every available info point towards the internals being exactly the same except for the dial.
Posted : 15/09/2014 5:05 pm
 poah
both the rct3 and the RC have LSC adjustment
Posted : 16/09/2014 3:16 pm
 LoCo
Top end assembly of the RC charger damper is different to the RCT3
Posted : 16/09/2014 3:17 pm
 hora
Budget buyers trying to pass off a oem lower fork as same 😆 😉
Posted : 16/09/2014 6:08 pm
Anyone got a solution to this, I've tried stripping down the air side and cleaned out excess grease, tried pulling up on the bars with no pressure in and rode it hard yet it still sags in about 10% unweighted and there is a clunk on top out
Posted : 09/10/2014 10:14 pm
Reports of problems like this were one of the reasons I opted for a Marz 350cr
Posted : 09/10/2014 10:24 pm
don't think it'll affect suck down but have you tried this? there do seem to be air migration problems with solo air forks, my revs used to build up mighty pressure in the lowers, didn't know about this burping technique though
Posted : 09/10/2014 11:00 pm
That video just shows the air being released from compressed lowers doesn't it? It might solve the 'can't get it to stay all the way down' non problem but I bet it'll introduce a 'can't get it to stay at full height' non problem. Xfusion makes a fork with little valves to equalise air pressure in the lowers with that outside but as far as I know: 1/ you do it with the fork extended 2/ it's more to do with dealing with air pressure changes when starting from the top of a great big mountain.
Edit: OK, I see what you mean now, air leaks from the air spring into the lowers? That's just crap then.
Posted : 10/10/2014 7:20 am
 hora
I guess if you suffer this problem you could ask Fisher to fit dual air internal with a part-contribution?
Posted : 10/10/2014 8:09 am
well my pikes have been back at sram now for over a week easily, I took them lbs 3 weeks ago today, and sram wouldn't allow them to send in until they gave the lbs a returns number
3 weeks today and still no forks, absolute dog shit of the highest degree
Posted : 10/10/2014 8:45 am
"Top end assembly of the RC charger damper is different to the RCT3"
what does that mean in real terms LoCo? I'm trying to decide if i build a bike which forks i'll fit, but can't see compelling reasons to buy the more expensive ones.
Posted : 10/10/2014 10:33 am
 hora
TBH would a everyday man like you or me really miss or notice anything different everyday?
If it was Fox 36 float R versus Fox 36 float RLC - yes.
Posted : 10/10/2014 10:54 am
Not sure Hora, thats why i was asking 🙂
I agree in principle though, most of the time these features such as travel assist and super damping are set and left alone at best, or not used at all.
Posted : 10/10/2014 11:35 am
 Sui
Mine seem to have done this "sticking down thing". Without reading the thread i had already pumped up and cycled the fork and for the most it seems to have done the trick, though it's still set in by about 5%. The tokens seem to do a grand job btw...
Posted : 10/10/2014 11:39 am
Look at the blow up diagrams in the manual/spare parts catalogue. The top of the damper is different as the RC version doesn't have the threshold lever, so it doesn't need all the associated gubbins.
Posted : 10/10/2014 11:43 am
stamion - Member
I think the table is out, I weigh 180lbs and am only running 60psi which only gives me 15% sag, I think there is one token inside, but haven't opened them to check so not sure. They are the best forks I have ever had, I just run them fully open (DH mode) all the time and occasionally get full travel depending on how gnarly the descents are, or on big drops. They are very firm and ramp up quickly which is how I like to ride, although they are maybe a little too firm for slow techy stuff, they gobble up the rough and fast stuff with ease!
Posted : 10/10/2014 1:18 pm
Hello one and all,
Ok I bought some 2015 pikes and have been using them for two weeks. Set the sag at 30% and thought I'd break them in for a while then add tokens etc
Anyhow, yesterday I noticed that the forks were stuck at around 25% unweighted.
Have followed this thread, pumped up the forks to 150psi and cycled them a few times. They are now stuck on around 5% . Is that right? Sorry for my nubeness. 150mm BTW
Posted : 29/06/2015 9:01 am
If you slide the end of a small zip tie down between the seals and the stantion (on both sides) when they are pumped up, does that fix the problem?
Posted : 29/06/2015 10:09 am
haven't tried that. but i guess my first question is that they are on 5%, that is not right? There is still air trapped?
thanks
Posted : 29/06/2015 10:11 am
Sitting at 5% with no load isn't right and it could be caused by a partial vacuum in the lowers (which you can check with the zip tie trick). But it could be other things too. E.g. a blocked transfer port and too much pressure in the negative spring.
Posted : 29/06/2015 10:16 am
zip tie trick worked thanks. Sucks (pun intended) that you have to do that to get expensive forks working properly. as a side note, i put a token in, dropped air pressure, forks work so much better
Posted : 30/06/2015 12:36 pm
Hey, did everything recommended(on here and by leisure lakes) Pumped it full of air, stretched it out, let all the air out, stretched it out, put in 10 psi,bounced it every 10, still no change! Last resort(didn't have any faith in it ), did the small zip tie, under the seals, hey presto , hiss, and it worked !!Thanks alot! now rides like a dream..me 160 solo rc Pike,12st,70psi, 1 token, 7 clicks compression, 6 rebound
Posted : 21/07/2015 10:21 pm
same issue here with a SID World Cup XX. Fork didn't want to move past 80mm even with 150psi.
Solution:
I pumped to 175psi.
Then while holding it wide open I pressed the air valve. Then I pressed all the way down and took all the air.
Then I open it all the way up again and pressed all the way and took the air.
It seems that the bottom and upper chamber equalize when the fork is at 100% open, so it felt like, equalize, then press and release air.
Repeated it 10 times, then pumped to 60psi and it stayed at 100mm as it should.
Posted : 29/03/2016 3:03 am
Funny that this thread pops up now, after I read through it last week suffering a similar problem.
In my case, no amount pumping, emptying, cycling and squashing would get the chambers to equalise. I opened up the air chamber, pulled it apart ([b]WHUUMPF[/b], don't forget your safety specs!) and cleaned up some of the masses of grease inside the air chamber blocking things up.
Right as rain now.
Posted : 29/03/2016 9:52 am
Hey, I have a similar problem on my Revelation Solo Air (2014). The uppers won't come out all the way. They sit (unloaded) at around 5% of the sag-scale.
When I noticed this and an overall bad behavior of the fork, I did a full service. I didn't change any sealings/hardware but took everything apart and put in new grease, damper-oil and lowers-oil. The fork seems to respond much better now but it still sits at around (little lower than) 5%.
I then tried every suggestion I could find online for this problem (burping the fork, pulling etc.). Nothing helped. Only when I release the air from the lower "hidden" (under the air bolt at the bottom of the lowers) air valve, the fork pops back up all the way. But when i but weight on the fork and release it, it only goes back up to around 5 % again.
Finally I took everything apart again, checked that I didnt put too much grease in (blocking of the air bypass) and put it back together - no luck.
While I still do not fully understand how the airflow in the upper tube works, my only suggestion is now to change the seals - does that make sense? Could it help?
By the way: When I cleaned the air tube, I noticed some debris (not sure if thats the right word in English?) on the inside of the tube on some spots. I wasnt able to take a pic... It was really hard to clean (using alcohol and a rag on a dowel) and I was not able to get it all off. I can only imagine, it is rubber that came off the seals (but they looked OK...). Any suggestions how I can get that stuff of? Maybe this is part of my problem...
I would really appreciate your help 🙂 Looking forward to your answers...
Posted : 26/04/2016 6:17 am
Hey, i got a little update to my post above.
So, now i got a basic service kit for my Revelation and installed new seals on the air-side. The with the new inner-sealing of the floating seal head it feels a lot firmer. I thought that may have been the problem. But not - after putting everything back together I have the same problem. The uppers are sucked in.
I took two pics. One with the uppers sucked in (after pumping the fork up to the right sag and pushing it in a couple of times). The second pic shows the uppers after letting air out of the hidden valve under the bottom-bolt on the air-side.
Is there anything else I could do besids sending it in for warranty?
Thanks!
Posted : 03/05/2016 5:41 pm
Buy some Fox's 😉
Posted : 03/05/2016 6:53 pm
Any other suggestions? I just also measured the distance from the dust wipers to the top of the stanchions. It's around 125mm as opposed to 130mm.
Posted : 07/05/2016 9:52 pm
If you look back to the first page of the thread it is clearly explained that the problem lies inside the airspring. The airsping lies entirely inside the LHS station; any tricks involving letting air in/out of the lowers will not affect the working of the airspring. There are two plungers inside the airspring that form two air chambers. When the fork is loaded in a particular position the air in the positive chamber can move (via the air transfer dimple) into the negative one. If the dimple is blocked with grease then the two chambers can't re-equalise leaving too much pressure in the negative chamber. Rockshox do put too much grease on the plunger O-rings.
Posted : 08/05/2016 9:27 pm
Not true, undesired pressure in the lower pushes up on the workings of the air spring too hence the problems it causes. Look at a schematic of the air spring
Posted : 08/05/2016 9:58 pm
So, enough pressure in the lowers to affect the airsping pressurised to 6 bar? How would the fork compress with all that pressure in the lowers?
Clearly some pressure is generated in the lowers when the fork is compressed and this might cause some issues but the suckdown effect is caused by the issue with the airspring.
Posted : 08/05/2016 11:24 pm
Thanks, but I think I was working at the right place. The "hidden" valve lets the air out of the negative chamber. I also changed the seals in the air-spring and I took out lots of grease to prevent the blocking of the dimple.
I think the bypass dimple works. Because when (with the lowers off) I push and pull the air shaft, I hear some "air sound" when the airshaft is nearly fully extended - i think that happens, when air passes trough the dimple. Right?
What else could it be?
Posted : 09/05/2016 9:59 pm
When you filled in the damper, was the rod pulled all the way out? If you miss this, when the rod is fully extended it will create a vacuum in the damper which opposes the airspring in the other leg, causing the sag you have noticed.
Posted : 09/05/2016 10:06 pm
Yes, that's the whole basis of this whole trapped air in the lowers problem. The pressure is high as it's fed by the high pressure in the -ve spring. Google 'pike burp' for more, it's a common problem, not just on pikes.
Easiest way to tell this is if you can feel the effect of the -ve spring, ie is the initial stroke nice and easily initiated, ie good small bump sensitivity. If you totally empty both chambers and pump straight up to say 80psi without cycling the fork, the -ve spring won't have had a chance to fill up so the initial stroke will be stiff, as you pass the port some air will go through, you might be able to hear it I can't remember, and after a few cycles the inital stroke should feel easily activated because the -ve spring is helping over that first bit of travel.
Were the air and damping leg shafts fully extended when you slid the lowers on?
Also, with the lowers off, does the damping leg shaft extend fully out and stay out? I seem to remember once I had put the damper leg top cap back on with the shaft partially inserted and when I tried to pull it out it would suck back in, because it would create low pressure in the damper - this might be enough to pull the forks down a few mm. When you empty the -ve chamber via the valve, the greater force from the +ve spring can push the fork to full extension despite this slight sucking from lower pressure in damping leg.
Posted : 09/05/2016 10:30 pm
