1x9 set up- would t...
[Closed] 1x9 set up- would this stop the chain jumping from the middle ring?
 hora
[#1209634]
Two questions really.
I have a steel Blackspire inner plate and a blackspire bashguard (ring god).
If I fitted these to my XT crank- it should stop the chain from jumping off on a 1x9 set up?
Also......could I run the 22T granny ring in the centre- is that possible? Dont laugh.
Posted : 11/01/2010 4:05 pm
 sv
Haha!
Is the 22t not 64BCD or something? Short cage rear mech and it should work with a 32T or similiar.
Posted : 11/01/2010 4:08 pm
 hora
Whats a 64BCD? Its a long cage mech that Ive got spare/knocking about.
Posted : 11/01/2010 4:11 pm
It'll help and will probably be enough to work fine in most circumstances but won't absolutely guarantee it.
LOL 🙂 The inner ring won't fit on the middle ring position - the bolt spacing is completely different.
Posted : 11/01/2010 4:13 pm
 sv
The middle/outer rings have a 104BCD (size of spider they fit) the granny is smaller and fits inside the others.
The long cage 'might' work its just got a longer throw on the arm, never tried a long cage and it really is all about chain tension.
Posted : 11/01/2010 4:16 pm
 hora
Ah. Good point.
So I need to spend some ££ and get one of these?
http://www.chainreactioncycles.com/Models.aspx?ModelID=35822
Posted : 11/01/2010 4:17 pm
 sv
That would certainly do the trick! Or the Pauls chain keeper thing, would also do away with your other gubbins, inner plate etc.
Posted : 11/01/2010 4:25 pm
 sv
[url= http://www.paulcomp.com/chainkeeper.html ]Pauls chain keeper info[/url]
Posted : 11/01/2010 4:29 pm
The roller device wouldn't really help since it only secures the chain at the bottom - the chain can still jump off the top of the chainring though in theory with the roller, you could back pedal to get the chain back on
Posted : 11/01/2010 4:49 pm
 ski
just 1x9 my setup & used the rohloff chain guide
[url= http://www.rohloff.de/en/products/speedhub/chain_guide_cc/index.html ]http://www.rohloff.de/en/products/speedhub/chain_guide_cc/index.html[/url]
Looked like it might have a bit more mud clearance than the Pauls version.
Posted : 11/01/2010 5:00 pm
 st
MRP now do a 1.x chain device for 1 x 9 set ups. About £35 from CRC but out of stock, there are others doing them for £40 though. Same idea as the Pauls one but more grrr looking in an MRP way.
Posted : 11/01/2010 5:46 pm
why a 22t ring?
Posted : 11/01/2010 5:56 pm
 hora
Honestly? I have loads of spare worny-bits for a full hardtail secondhand build EXCEPT a front mech and front mech shifter. Scared to ditch the granny ring.
Posted : 11/01/2010 6:34 pm
"Whats a 64BCD? Its a long cage mech"
A 64mm Bolt Circle Diameter for granny rings
Middle ring position is a 104mm Bolt Circle Diameter
Shorten the chain so it goes round the 2 biggest rings + 1 pair of links and the long cage mech will work. It'll be more in tension than a short cage mech, spending no time in the slacker end of its range of tensioning. If it becomes a problem you can buy a short cage mech later
"one of these"
That lower roller would only really help with stopping the chain coming off under back pedalling, or if the chain is going to be jumping up and down ridiculously
A top guide (MRP 1x, Rohloff etc) will guarantee the chain won't come off under normal pedalling, but with an inner and outer guide ring you should be alright for normal riding. Having an inner guide ring should help with back pedalling too
A lot of people use a bash ring and an Ngear jump stop to do a similar job.
"Scared to ditch the granny ring"]
Don't be, unless you plan to ride the bike up really steep (sloppy) hills all day long.
Posted : 11/01/2010 6:46 pm
So, advice please...
If I'm switching to a 1x9 set up I need:
A chain guide + what type of mech? Long or short?
Posted : 11/01/2010 6:51 pm
 hora
http://www.jdcycles.co.uk/components/chains/n-gear-jump-stop-chain-guide
Wow, thats inspiring- great recommendation.
rockitman. I'm using (as Ive got one knocking about) - a outerbashguard, the above and possibly washers in the chainring bolts (if needed).
Posted : 11/01/2010 7:16 pm
 sv
I still lost the chain (occasionally) when using a bashguard/n-gear jump stop. The chain keepers are the answer IMO.
Posted : 11/01/2010 8:35 pm
I use a 36t front ring, short cage Sram X.0 mech, Pauls Comp Chain Keeper and 11-34t rear cassette. No problems with this set up 🙂
Posted : 11/01/2010 9:32 pm
have a look at this
Posted : 11/01/2010 9:36 pm
 hora
Can you buy the chainkeeper in the UK?
 hora
bonesetter that is a very very short chain. You'd snap the shifter lever climbing upto the bigring 😯
Posted : 11/01/2010 9:37 pm
Here's my current 1x9 on the Paradox
Posted : 11/01/2010 10:14 pm
 hora
How often do you throw a chain? Or...snap one?
Posted : 11/01/2010 10:30 pm
 Andy
Shameless plug: Have just taken an N-Gear jump stop off my inbred if anyone wants one. PM me please?
Posted : 11/01/2010 10:34 pm
Hmmm Middleburn Uno's might be the answer as I have yet to throw my chain on my 1x6 set up (8sp)
SSP
He he. I like this set-up for its simplicity and not having to ever shift the front. The gearing is set just right for the riding I do, and it looks cool too
The chain never drops, and yes the tensioner is tight, but I don't think it does any harm
Posted : 11/01/2010 10:36 pm
I have this set up:
With a stinger underneath:
I started off with just the blackguard on the inside and bashguard on the outside, never dropped the chain but on some rooty DH trails I could feel the chain slipping. Had absolutely no issues since I added the stinger.
However, with the money I spent bit by bit I could have bought a LG-1, which would probably have been lighter.
Posted : 11/01/2010 11:00 pm
MRP1.X is the way to go.
Posted : 12/01/2010 12:05 am
That looks good up front,scott mcave.
Posted : 12/01/2010 1:45 am
I just left the front mech in place and locked it out using the adjuster screws on my FS. I would like a LG1+ but they do look a bit too core and its a big lump of cash spent if I change my mind.
I might change my SS into a 1x9 but havn't decided how to yet it already has a bash and a stinger so maybe a jump stop is all I will need at the front.
Posted : 12/01/2010 7:13 am
 hora
Andy YGM re the N-Gear
Posted : 12/01/2010 9:04 am
I dont seem to.
Posted : 12/01/2010 12:05 pm
 hora
Not you- t'other Andy!
Posted : 12/01/2010 12:07 pm
