I've a set of pikes. They are the last gen, 2015 I think
Was bought at 140mm and I've lowered them a few times going from 140/30 and 20. Is it possible to go the other way and extend them to 150mm ?
Thanks
Hi
I believe so
I have had the same set of Pikes at 120/140/150 just by changing the internal shaft.
I can’t see why yours would be any different
Steve
Yes it's possible, just a case of changing the air shaft. Coincidentally, I've just gone from 150 to 120 with my pikes so if yours are 27.5 and you want a 2nd hand shaft then drop me a PM.
Can go up to 160 travel on the Pikes with an airshaft, you can retro fit the Debonair shafts too
If you are buying a new airshaft the Debonaire is a no brainer.
The incremental cost is peanuts
Thanks guys wasnt sure on whether I could extend them or not. So all pikes can go to 160?
Cheers @stevextc think I'll go for the debonaire upgrade if I can find a 29er 150 in stock.
I got mine from Zee Germans, they have your size in stock.
https://www.bike-discount.de/en/buy/rockshox-pike-29-debon-air-upgrade-kit-734549
