Who said the mk2 casing addresses the issue eskay? (Since your earlier post which said they hadn’t addressed the issue)
I don’t quite understand how the first battery can last 2-3 months and then it deteriorates so rapidly. You have to remove the plastic tab from under the battery cover when you first get them so its not like you haven’t already broken any factory seal from the moment you first use them. They should be as water proof with the second battery as with the first?
And I haven’t seen any evidence of water ingress in mine despite taking precautions to dry them out.
If it is a water ingress issue, then I can’t believe that every single unit that has been out in British weather hasn’t been returned. Are they fit for purpose in British conditions?
Its just a bit annoying to be without it.
