Ti 456 buffing
[Closed] Ti 456 buffing
[#676228]
There's a few marks/light scratches apearing on my ti 456, from the car car rack gripper and from general usage. When I bought the frame I'm pretty sure Brant said to use a normal pan scouring pad and go gently with the rub action.
I was just wondering if it's as simple as this, or do I need to do this in any specific direction. Also does this method apply to the bead plasted shiny shiny areas.
Ta.
Posted : 01/07/2009 12:47 pm
Scotchbrite pads are correct, although TBH you will get some more marks soon enough, however if it really bothers you then go for it.
Posted : 01/07/2009 9:07 pm
Is it bead blast finish?
Posted : 01/07/2009 9:29 pm
Cheers for the replies.
Yes mine is the one with the bead blasted logo and flames, there are some
marks on this area and I was wondering if the approach was the same.
Posted : 04/07/2009 11:54 am
Deffo dont go near it with a Scotchbrite pad then! Mine has quite a bit of marking too, but there is not a lot you can do.
Posted : 04/07/2009 12:17 pm
 gamo
As bdb says scotchbrite is for brushed finish
frames.
Posted : 04/07/2009 12:51 pm
