Tell me about... he...
[Closed] Tell me about... helicoils
[#3297199]
The pedal ripped the thread out of the driveside crank arm on my road bike today. I seem to remember helicoil being an option. Is that right and if so what do I need and what do I need to know.
Posted : 30/10/2011 9:45 pm
Helicoil will work and usually stronger than the original. Taking it to an engineers is usually cheaper than doing it yourself.
Posted : 30/10/2011 9:50 pm
You'd need a steady hand or a pillar drill, if you have neither of these get someone to do it for you instead. Should work fine.
Posted : 30/10/2011 9:55 pm
I believe in helicoils you sexy thing... i agree with craigxxl, you have to have the correct tools to do it. you effectively have to drill out the current threaded hole then re-thread it to allow the helicoil to create the desired thread. it is a simple job but you need the kit, where are you in the country ?
Posted : 30/10/2011 10:02 pm
helicoils are not common in unusual sizes such as a pedal thread especially as one side is a reverse thread. Still possible however
Posted : 31/10/2011 8:30 am
cyclebiker - Surrey.
What sort of price are we talking? These are generic cranks that came on a cheap (but good) used frame I bought so I can probably replace them cheap enough
Posted : 31/10/2011 8:48 am
I would think around £20 for a shop to do it - the insert will be a few pounds and it won't take long to do.
Posted : 31/10/2011 8:56 am
As they are cheap generic cranks, you'd be better off picking up a decent set second hand and swapping the rings.
Posted : 31/10/2011 9:01 am
Bike shop should have the helicoil kit
Posted : 31/10/2011 10:45 am
I once bought a 2nd hand bike which turned out to have a helicoiled thread in one of the crank arms. It didn't really last long, half of it came out with the pedal when I was changing them, and that was the end of that.
Posted : 31/10/2011 10:52 am
I'm gonna give it a go with a [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=55945 ]pedal tap[/url]. If it doesn't work out I've only lost a fiver and with have yet another unusual tool to add to the collection.
Posted : 31/10/2011 10:53 am
