Viewing 40 posts - 41 through 80 (of 125 total)
  • Tazzy's Wobbly Rings – Anything current? Anyone keen?
  • cynic-al
    firestarter – Member
    How come they didn’t work back in the day but they do now ? Snakes piss
    Different orientation – and jury out on “works now”.
    tazzymtb
    yep wiggo used elliptical rings cos they are gash 😀
    and ned overned
    and the niner ergon mtb folks
    and the specialised factory xc team
    and the garnim team
    and carlos sastre
    and some single speed giffers 😀
    rOcKeTdOg
    Gotama – Member
    I don’t think anyone is contesting whether they fit a swift.
    @Gotama this is for your Swift? (If it won’t fit on yours I guess it won’t fit mine)
    whatever you say chap 😆
    njee20
    He said jury’s out, not they’re gash. If they definitely worked then every single rider in the peloton would use them, plus SRAM and Shimano would make them!
    I’m interested to try them (elliptical rings generally). Doubt you do 88mm BCD anyway though? And I already run a 36t, so it’s not looking good!
    tazzymtb
    have a chat to the goldtec chaps, they can cnc all sorts of variations. They have made a dinner plate 60 odd tooth elliptical for a track bike for some record attempt thingy wotsit.
    firestarter
    My mate uses rotor cranks on his road bike, he can’t decide for or against them
    I like the idea of having two free teeth on the crank 😉
    bikebouy
    Tazzy, count me in, I’ll have one.
    Currently 32:17 and have a 19 for spinney climbing stuff so guessing a 34t based on what you’ve said so far. Using Sram XO cranks.
    When will know you’ve got them or should we go direct??
    Cheers.
    takisawa2
    I’ve been running one for about a year & really like it. They last very well. They make the singlespeed pedal stroke smoother & I certainly didnt notice the 1 tooth increase I went with.
    Tazzy…just out of intrest, do you think they would work if I ran two as a dingle speed ?
    IMAG0335 by pten2106, on Flickr
    rogerthecat
    Taz up for 2 please – currently running 32 so guessing I’ll need 34
    sp
    Humm interested, up one tooth, up two teeth, I hate these decisions 🙄
    Ball park cost of 104 bcd 33T/34T
    STATO
    Im slightly confused by the +2t idea. A normal 4 arm crank the smallest you can (easilly) fit is a 32t, so the max leverage ratio any oval ring could have would be same as the 32 (ie. point of chain contact from centre of axle)? Does that mean that you choose a 34t oval ring as it would have more speed but same power/ability to climb as the 32?
    Thoughts?
    Ta.
    Also, do they work with 9speed chain?
    tazzymtb
    righty ho folks, I’ll have a chat to the goldtec boys and see what best price we can sort for a group buy. It may be easier if I can just get a code from the boys and email it to the interested parties and you can deal direct with your discount.
    Last time I organised it I was a total dobber and forget to get the postage cost off folks so ended up out of pocket, but with a warm glow of spreading the wonky love. I’m a bit special like that! 😕
    bikebouy
    Tazzy, no problems, will sort it either way to suit you no problems 😀
    Thanks for the update and the thread, came just at the right time for me this..
    Muchos Grazias
    drofluf
    I’ll be in if the Shimano Centrelock version will fit my Middleburn cranks…
    tazzymtb
    they do direct mount uno version for middleburn, or the normal ones work with the standard 4 arm 104 bcd middleburn spider.
    drofluf
    tazzymtb – Member
    Thanks – is that the one they describe as centrelock here? Bought the vranks this week second hand and still making sure I understand what I need 🙂
    tazzymtb
    looks like middleburn direct mount version. i’ll check tomorrow for you.
    drofluf
    Thanks – appreciate it.
    peanut
    Loving my 35t Tazzy, may need to get a 33t one next.
    Northwind
    Cheers Tazzy!
    tazzymtb
    Right folks. From friday the 18th until the 25th the wonky rings will be available on the betd goldtec website for a discounted price with free postage as well, so order direct and have fun.if you want the tazzy guide to set up email me as there are a couple of cheeky tricks to get perfect chain tension. Cheers.
    nedrapier
    Good work! Thank you!
    Could you put your email in your profile? It’s worked out well so far, cos I wouldn’t have started this thread if it had been in there!
    Or send me set up to the address in mine.
    Cheers again,
    Ed
    drofluf
    Thanks!
    Gotama
    Thanks tazzy, will give one a try. As above could you pop your email in your profile or drop me an email (address in mine) with the set up….or post the technique in this thread. Ta
    drofluf
    tazzymtb – Member
    Any idea how we get the discount? They’re still showing as the same price
    bikebouy
    Muchos Tazzy.
    I’ll need the setup as I’m using Niners EBB.
    JonEdwards
    Also interested in one of these – was just going to buy one direct, but I see they’ve put the price up now, so would be interested in how to do the group buy thing – I’d mail tazzy if I knew what his mail was…?
    Gotama
    Me too. Almost certain they were £35 when this thread started.
    mattjg
    is it these?
    http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=440&Name=Goldtec+OneKey+Rings
    ready to hit the button when the price drops …
    Tazzy could you put your tips on a blog and link them, (unless you have a reason to keep them private)? Posterous takes moments to set up if you need a publishing tool, or I can do it for you.
    Gotama
    Yep, they’re the ones.
    Cheezpleez
    Price is showing as £34.99. Are we expecting it to go down from that? It seems to have gone up then down to the price it was before…
    I’m confusticated 😕
    mattjg
    @cheez it was defo showing 45 quid a couple of hours ago.
    takisawa2
    Bikebouy…mine is on a SIR.9.
    I set the tension with the cranks as in my pic.
    c_klein87
    Anyone tried these on a 1×10 setup?
    http://chris-noble-mtb.blogspot.co.uk
    onandon
    The CRC school of product discounting.
    And for that reason I’m ooooot….
    Gotama
    Yeah, does seem that someone was trying to be a bit clever there. Ah well, happy paying 35 quid for the ring so i’ll give one a try.
    tazzymtb
    The rings are 45 quid. Their it gimp fluffed up when he put them on a few weeks ago. Hence the return to normal price before dropping to the discount for the next week.
    drofluf
    Anyone know if a 36T will fit on a Swift?
    tazzymtb
    yes in the outer ring position, if using standard cranks. With an uno it’ll be tight and the EBB will have limited movement (be at the front as it were)
    drofluf
    Thanks – I’ll go with a 34 in that case I think. Can always put a smaller freewheel if I need to.
The topic ‘Tazzy's Wobbly Rings – Anything current? Anyone keen?’ is closed to new replies.
