So are Dyson vacs r...
[Closed] So are Dyson vacs really any good?
[#465030]
And if so which model?
Or something else?
Posted : 11/04/2009 7:27 pm
yes. I think we've got the DC04 model. It's very good. Had it for 8 years now, just needed a slight rebuild a couple of years ago after i'd vacuumed up part of the carpet.
Posted : 11/04/2009 7:28 pm
Flimsy plastic junk. Get a Henry.
[b]<THREAD CLOSED>[/b]
Posted : 11/04/2009 7:50 pm
miele.
Posted : 11/04/2009 7:51 pm
rubbish get something else
Superb, but can suffer reliability problems, we took out a 5 year ext warranty with dyson for a fiver a month for the first year so if anything breaks they just replace it.
Posted : 11/04/2009 7:53 pm
We've had one for 7 years and its just started to overheat regularly. Going to get a Miele next, well now.
Posted : 11/04/2009 7:55 pm
Henry if you find you're regularly vacuuming up sand, sawdust, odd piles of rubble ie if you're renovating a house.
A miele for everything else.
Dyson schmyson.
Posted : 11/04/2009 7:56 pm
Not very good, we had three industrial Dysons for the office cleaners at work - loads of warrenty repairs & they all packed up in under two years - replaced with Hoover Aquamasters & they're still going strong with zero issues.
Posted : 11/04/2009 7:57 pm
Works well but very weak if you go for multi-colours.
I claimed all the time in the 3 yr warranty from the dam thing breaking bits while in use.
Cleaning was very good though.
Posted : 11/04/2009 8:12 pm
Henry,
Posted : 11/04/2009 8:13 pm
MrNutt speaks Great Wisdom...
Posted : 11/04/2009 8:14 pm
i got a henry last time we had to get a new vac.
i did the right thing.
you should too.
Posted : 11/04/2009 8:17 pm
Early Dysons worked well but they didn't now enough about designing for reliabilty, that's all sorted now and they come with a 5 yr guarantee. I would reccommend a DC25 (on offer in Comet at the moment).
Meile's are well made but will cost you 2 or 3 times the purchasing cost over it's lifetime in bag cost.
Unless your a builder don't bother with a Henry - cheap and tough but a large percentage of the dust will get blown back into the room which kind of defeats the point.
Posted : 11/04/2009 8:19 pm
Just to buck the trend. Had a DC01 for 12 years... never missed a beat.
However, as there is only one carpet in the house so it hasn't got many miles on the clock.
Posted : 11/04/2009 8:20 pm
No.
We've got a Sebo and it's fantastic - lasted through the renovations we've been doing over the last 2 years
sucking up dust, soot, bricks, wood with no complaints.
Our local Dyson dealer also sells Miele and Sebo and he has a Sebo which was recommendation enough for us. He says Dyson repairs keep him in business...
Posted : 11/04/2009 8:31 pm
Another Sebo user. Proper vacuum, doesn't need a face on it to market it, just vacuums properly.
Posted : 11/04/2009 8:39 pm
I'd rate our Sebo, quality without a miele price (nearly tho!)
Dyson, hoover once, empty into a bag to go in the bin, then have to hoover it all again. Messy!
Posted : 11/04/2009 8:41 pm
ours only needed rebuilding as I used to vac up all the plaster / wallpaper that i'd stripped off the wall at the old house... I think an industrial one would have struggled too!
Posted : 11/04/2009 8:44 pm
I went to the local tip today to drop off some garden stuff.
they had 11 broken Dysons lined up by a skip 🙂 .
I made a point of counting them so i could tell the wife
Posted : 11/04/2009 8:54 pm
We have one of the pet hair cylinder ones, with two turbine brushes. It's really good. The only other one we saw with a turbine brush was a Miele one and that looked like a pretty pathetic affair. And you only got one, we have a big one for carpets and a small one for stairs and sofas etc.
I really like mine. Oh and ignore the max fill line on the cylinder. It works fine until the thing is almost full about 3x more than the max line indicates.
Posted : 11/04/2009 9:00 pm
used to have a Dyson - now got a Sebo - only way to go - Dyson doesn't compare
Our Henry has been through more abuse than any hoover deserves to suffer and is still going strong. It's fallen off scaffolding, been used to clean out hot ashes, been filled with water (not related to the ashes!), and is presently proving useful cleaning up building rubble.
Posted : 11/04/2009 9:08 pm
Sthil, sucks the carpet from the underlay.
Posted : 11/04/2009 9:19 pm
Our local re-cycle tip manager showed me around last year (it happens if you appear 'too' interested) and he showed me the ISO container full of Dysons (hundreds of the things), he told me he sends the container to a company in London every 3 months who pay a couple of hundred pounds for the spares. He told me they have a few of the others but had not seen a Henry for years. Our Henry has been around for 10 years plus, two house re-builds, looked so sad after one I bought a Miele which was good in a BMW -ish way, lasted three years, before Henry was brought back into the house. so a Henry
Posted : 11/04/2009 9:31 pm
Henry. You can use it to clear up the bits that fall off Dysons as they (not so) gradually disintegrate.
Just don't buy a Hoover. Worst thing ever, wouldn't pick up, overheated and cut out and was basically just an ineffective POS.
Posted : 11/04/2009 9:56 pm
the_lecht_rocks - Member
miele.
on hols last week and agree
at home we are on our lost count of number of dysons because mrs antigee believes they are great but only vacs the area of carpet in front of the fireplace
HEAVY SH1TE and despite claims more powerful than a whirlwind they spend all their time ripping the top layer off the carpet and will not WILL NOT pick up grit or anything heavier than a 2.5mm long piece of spag' CRAP CRAP CRAP
Posted : 11/04/2009 9:59 pm
and F'ING NOISY
Posted : 11/04/2009 10:00 pm
Have a DC7 and frankly unimpressed. Too blasted complicated with removable plumbing tubes and fittings all over. It's now stuck together with gaffa-tape because half the clippy things have broken and seals failed.
Posted : 11/04/2009 10:07 pm
Another Sebo user here, we use a Henry at work, & always have done for the last 20+ years, I think we are on our third, & that makes them the toughest out there!
Henry's are crude though, I wouldn't use one in the house, Sebo's are just very well designed & work well, what more could you ask?
Posted : 11/04/2009 10:17 pm
Another happy Sebo user, ours has been going strong since 1993, it sucks!! 😀
Posted : 11/04/2009 10:32 pm
Like Harry our DC01 is going fine except I had to buy a replacement handle fron ebay when ours broke. It's not the greatest vacuum in the world though. I'd be interested in trying a Henry given they get rave reviews everywhere you look from people using them to destruction, except they don't destruct!
Got a DC04 and after a single issue with the tube it is still going strong after 6 years.
Vendor told me that he was fixing a lot of dysons. He also, after a lot of prodding, told me he SOLD a lot of them. As a result he's more like to fix them. If you only sell one Miele a year then it is unlikely you'll need to fix it. If you sell a bazillion dysons then you're more likely to seem 'em back. Simple statistics really.
Posted : 11/04/2009 10:43 pm
Don't give it too much thought. It's just an implement for picking up rubbish from your floor. There are far more interesting things to devote your time and effort to.
Posted : 11/04/2009 10:48 pm
 Creg
A mate of mine dropped his down the stairs so claimed on his insurance and got a replacement. The rotor housing on the dropped one is all that is broken on it.
Ive had it in my house for 2 years now (the dropped one), gets regular use and works a treat..after being dropped.
Posted : 11/04/2009 10:56 pm
Got a DC05 here. Been used for 7 years domestically and now 2 years of cleaning up after mountain bikers/snowboarders around a big chalet. Still going strong. Actually, it cut out today for the first time ever but I think the filter just needs cleaned - haven't done that since, well, ever...
Posted : 11/04/2009 10:57 pm
[i]Don't give it too much thought. It's just an implement for picking up rubbish from your floor. There are far more interesting things to devote your time and effort to. [/i]
Exactly. Its just a vacuum cleaner FFS. 🙄
(Have a DCO8 Allergy and a DC16 handheld but still agree with my comment above 🙂 )
Posted : 11/04/2009 11:03 pm
Utterly underwhelmed by Miele - great for 10secs until the bag clogs up then next to useless.
My DC05 Motorhead does need regular fixing, but seems OK. Not the greatest at picking big stuff up but at least it doesn't need it's bag changing every 5 minutes and the filters are good - pretty much no dust gets re-circulated.
Posted : 11/04/2009 11:16 pm
We have a Dyson Ball, it is great, very easy to use, and works really well.
We had a DC01 for years it was great as well.
We have a Henry, it just doesn't like picking up dog hair from a carpet, good for cleaning the car though.
Posted : 11/04/2009 11:21 pm
Hmm, this is strange. I've had two dysons (one I gave away still working, traded it for a more powerful later model) and never had any issues. They are the cylinder kind tho not the uprights, current one is a DC20 animal. It picks up all sorts of things - leaves, bits of food, clothes tags, sweet wrappers, anything I can't be bothered to bend down to pick up. Also various things I didn't want it to pick up such as Mrs Grips earrings etc. Seems to have great picking up poiwer to me.
Posted : 12/04/2009 12:21 am
Our dyson is great at getting pet hairs out the carpets. its 10 years old now and has had a battering and is still going strong.
Posted : 12/04/2009 11:30 am
We have 3 vacuums, one George, Its 15 years old and was used daily for car valeting, for 10 years! (Georges are Henrys with a pump for water in them). We have a normal Henry which is used in the workshop and is totally abused (poor thing) and we have a DC04 for the house, apart from wear and tear on things like hoses none have them have ever gone wrong.
They are just vacuums we use them and abuse them, end of story.
Posted : 12/04/2009 12:23 pm
I have a DC08 animal for the last 4 years, it's done a lot of work, banged about we have 2 border collies, often at the beach, mud in the house etc. It's a great performer, cheap to run. The Henry we had for a year before was OK found it good but nothing compared to the DC08. The henry is relegated to the garage.
Posted : 12/04/2009 8:21 pm
A few weeks after buying our orginal Dyson, got a call which resulted in what turned out to be a vacuum cleaner salesman visit. It lasted over 2 hours (!) but was totally fascinating. It was for Magestic FilterQueens, which is in another league in performance and another galaxy on price!!!!
I learn't what a "Crevice Nozzle" is, the thing had a Lazy Duster that creates a vortex of air in the room, sucking in the dusty stuff and removing dust, you could even use it as a paint sprayer for the car.
The 'display' ended up with him vacuuming our bed to show what dust mite crap looks like.....
totally stunning machine, gobsmacking price, lifetime guarantee but if we'd bought it ( then equivalent of 4 Dysons ) after 4 Dysons, it would be cost effective. They'd even refund the price of our new one cos they hadn't seen that ( then new ) model before. Baby no. II had just arrived, so no chance.
We're now just watching dyson 2 die........
hey ho......
Why do Miele use bags? it just seems old technology now.
Q
Posted : 12/04/2009 8:25 pm
We're on our second Dyson. The first one was a grey and yellow pile of crap.Got a mate at the local tip that financed his holidays,by stripping and refurbing Dysons. Unbelievably Wife of Riley bought a Dyson Ball,which is even worse. Horrible ,flimsy thing that very quickly lost its' initial cleaning power.
Surprised that there's been no mention of Panasonic.
Posted : 12/04/2009 8:55 pm
