Revelation Damper O...
[Closed] Revelation Damper Oil
 Tim
[#959588]
Hey up
Might be a bit of a daft question, but I cant find the info on the net (googlefail)
Need to replace the motion control assembly in a revelation, so need to replace the oil...
...whats the best stuff to use?
In past experience, there was always the official fork oil, and then identical motorbike oil for about a 10th of the price 🙂
Tim
Posted : 17/10/2009 10:43 am
 nbt
AIUI, motorbike oil has additives to help the seals expand - which is fine ona motorbike with all that weight and power, but can cause stiction problems on an MTB. YMMV
Posted : 17/10/2009 10:46 am
most don't - those that do are usually marked as containing something like 'seal swell'
Rockshox re-brand Torco RFF as their own but bizarrely change the numbers e.g. Rockshox RS15 is in fact Torco RFF 20
Rockshox oils chart [up to 2007] can be found here
http://www.sram.com/en/service/rockshox/oil_chart.php
Posted : 17/10/2009 11:02 am
 Tim
Ah ok cheers
So according to that I need 5wgt and 15wgt
I'll nip to halfords then, and avoid anything that mentions seal swelling 🙂
Cheers!
Tim
Posted : 17/10/2009 11:08 am
Use Silkolene Pro RSF 2.5wt and 5wt
[url= http://www.pvdwiki.com/index.php?title=Suspension_Fluid ]Suspension fluid explained[/url] (excellent resource).
[url= http://www.pvdwiki.com/images/c/c3/Silkolene_Mix_Chart.pdf ]Mix chart[/url]
So you'll need to mix 2.5wt / 5wt in a 82% / 18% ratio to get the required viscosity.
Cheers.
Posted : 17/10/2009 11:15 am
Go to a motorbike shop for Silkolene.
Don't think you'll find Torco here in the UK.
Posted : 17/10/2009 11:35 am
Torco is reasonably easy to get here but yes, Silkolene or similar will be a lot easier to find from 'bricks & mortar' shops
Posted : 17/10/2009 11:43 am
 nbt
for what it's worth when I was looking for 15wt for my revelations, Crazy legs offered to pick it up from the motorbike shop round the corner from his house. They were charging £15 per litre. I paid £8 yesterday in my LBS.
Posted : 17/10/2009 1:13 pm
