Pike sag - How much...
[Closed] Pike sag - How much do you have?
[#1443941]
I get 20mm seated and approx 40mm sag when standing on my 351 coil Pikes and wondered if that was too much or too little...
Your feedback is very much appreciated.
Posted : 24/03/2010 8:38 pm
40/140 = ~29% = spot on
Posted : 24/03/2010 8:39 pm
Probably the same as my 421s.
Retro - Cheers mate
Scott - are 421s air or coil and how much do you weigh if you don't mind me asking...
Posted : 24/03/2010 8:48 pm
I'm probly buying some second hand 351's of a friend tonight. Does anyone know how you check which spring is in it cos my mate doesn't know what one's in there? I'm assuming you can gain access to the spring but is it labelled once you get at it?
Posted : 02/04/2010 6:00 pm
they are dif colours,
yellow=med
red=firm
black= x firm
i think!
easy to get at them, just use a large socket on the left hand leg upper
Posted : 02/04/2010 6:01 pm
 GW
Set sag standing in your normal riding position, you won't ever give suspension a hard time while seated.
what do you weigh? and what spring are you using?
Posted : 02/04/2010 6:03 pm
 GW
if he doesn't know, they'll more than likely be the standard meduim spring
Posted : 02/04/2010 6:05 pm
Ok thanks. I'll look forward to having a tinker later!
Posted : 02/04/2010 6:14 pm
GW - It's the spring that came with it and i weigh 14.5 stone(s)
Posted : 02/04/2010 7:36 pm
Not enough.. supposedly standard spring - barely 25 mm from 140 mm. and these days I am heading for 13 stone.
i suspect the springs are a bit random
Posted : 02/04/2010 7:49 pm
About 20mm I think.
Posted : 02/04/2010 7:55 pm
 GW
I'm up to about your weight just now after hybernating most of the winter and the X-firm spring is what I need. It'll depend slightly on how you ride tho too, if you jump/pump your bike through everything or are reasonably fast DH you'll need X-firm but if you're more of a sat down pedalling mince about type rider (ahem.. TJ) I've seen 15st riders get away with the firm.
If I were you I'd phone TF tuned for your new spring and be honest about how/where you ride.
Posted : 02/04/2010 10:47 pm
Who me GW! I am your star pupil!
Posted : 03/04/2010 1:03 am
Personally I'd go with Rock Shox' recommendation over sag. For example, with a red spring, my Pikes sagged the 'correct' amount, but on the trail it's far too soft. So I stuck in a fat pie eater spring, which only sags around 20 but out on the trail the fork feels sooooo much better.
Posted : 03/04/2010 3:12 am
Thought i was gettign too much, they seem to blow through the travel.
My riding style is full-on, whether up or down.
Not sure now whether to get the spring or some new forks...
How much did it cost 'all-in' to change the springs, where, etc?
Posted : 03/04/2010 9:29 pm
I got my Pikes and I'm very pleased with them but I think I need a softer spring. They have an xfirm inside but i think i need a firm as I have little sag and they won't bottom out.
How much do you weigh and what spring is it if you don't mind me asking?
Does anyone have a firm spring please?
Posted : 09/04/2010 10:09 pm
Giant Jaunt - I feel a swap offer coming on...
Swap you the standard spring for the XFirm?
Posted : 09/04/2010 10:27 pm
Hi. Thanks for the offer but I think it's a firm I'm after. The xfirm feels great but I'm not getting full travel or much sag so I think the firm should be perfect. There was a standard spring for sale on ebay recently but don't know if it's still there.
Posted : 10/04/2010 12:47 am
GJ - Cheers for the response, how about first dibs on the XFirm when you come to sell?
Posted : 10/04/2010 10:24 am
Yeah sure. I'll let you know.
Posted : 10/04/2010 1:21 pm
