OT - Octavia 1.6fsi...
[Closed] OT - Octavia 1.6fsi drinking oil!!!
 DrP
[#3915565]
Already posted on Briskoda, but as they get about 5 visits per year, I thought I'd try here!
I'm sure I'm burning oil somewhere as recently I'm getting through a tank of oil in about 700miles!
Also, the car seems to be "running rough" - just a bit hesitant at low revs, and idles like a pig!
I've a feeling i'll need to take it into the garage to get it sorted, but wanted to check here as to common problems that I could have a look at myself?
Was planning on taking out the coil/spark plugs to see if there's a particular cylinder affected (oil residue/burnt plug).
Any other common sites for oil to be lost from? (there's no obvious oil leak on the drive etc, so sure it's not coming 'out' of the car!)
Any VAG mechanics/experts here who could lend a hand, it would be much appreciated!!
DrP
Posted : 26/04/2012 2:51 pm
Have you checked under your car when it's parked to see if there are oil stains? If there are not, and it's a petrol engine - and it's running rough, it sounds like oil is getting into the combustion.
1. Gasket issue
2. Cylinder issue - did you buy it new or second hand. If second hand, botched engine replacement/refurbishment?
Posted : 26/04/2012 2:54 pm
lift the oil filler cap is the oil clean or do you see "mayo"
failing that is there oil on the floor when the car is parked up over night?
if its no to both the oil maybe getting into the cylinder heads
Posted : 26/04/2012 2:55 pm
 DrP
Bought second hand from dealer - was fine at first, only recently had the trouble....
Will looking at the plugs give an indication at all??
DrP
DrP
yes they'll be oily
Posted : 26/04/2012 2:56 pm
any smoke out of the exhaust either when running or on start up what do you mean by a tank of oil ? plug tips should be a light coffee colouor and look dry
Posted : 26/04/2012 3:25 pm
 DrP
Tank/sump - it's using all it's oil up - from 'full' on the dipstick to nada!
Oddly - no smoke/coughing from the exhaust...
Thanks for the help so far - will see how the plugs look tonight...
DrP
Posted : 26/04/2012 3:29 pm
 hora
When did you buy the car, what plate is it and how many miles?
Also post it here: http://www.pistonheads.com/gassing/forum.asp?h=0&f=23&mid=70159
Posted : 26/04/2012 3:35 pm
Full on the dipstick window to nothing on the dipstick window will only be about a litre nothing on the dipstick at all will be 4-5 litres which is a hell of alot for 700 miles.
check sump plug is not loose
Check oil filter, if the 1.6 FSI is anything like my 1.4FSI then it will be a paper refill type within a plastic housing near the top left of the engine so shold be pretty easy to see if it is damaged. There is either 1 or 2 o-rings within the plastic housing on my car.
Posted : 26/04/2012 3:42 pm
Pidge,
If you promise to go riding with me I'll take a look at your Skoda!
I've just finished rebuilding the suspension on my DC2.
DAVE
Posted : 26/04/2012 3:56 pm
 DrP
Oh yeah - I never replied!!!
You around at the weekend?? Sunday eve?? Might be able to get out for a night blast locally.....
DrP
Posted : 26/04/2012 4:05 pm
Back to the dealer pronto!
Posted : 26/04/2012 4:06 pm
 DrP
I bought it nearly 3 years ago! Think they'll be less than interested now!
DrP
Posted : 26/04/2012 4:08 pm
DrP not stalking you but were you parked near Stanmer Tea rooms last Saturday afternoon?
Posted : 26/04/2012 4:09 pm
 DrP
Were you the one looking through the nearside rear window really going for it??
(No, I wasn't!)
DrP
Posted : 26/04/2012 4:14 pm
fair enough. just remember someone loading a commencal onto a smallish hatchback and wondered if it was you.
Posted : 26/04/2012 4:21 pm
The fact that it's running rough alongside loosing mega amounts of oil, could well indicate it's near dead. If the damage is already done then it's already done. But it would be worth getting it seen to ASAP, hoping that it's something that can still be saved.
Sell it quickly! Ebay?
Posted : 26/04/2012 4:22 pm
ah, octavia's not the smallish Skoda. ignore me...
Posted : 26/04/2012 4:23 pm
 CHB
I have an Audi A2 with the 1.6FSI engine (presume its the same lump from approx 2003-2005?).
Coil packs are known to fail on these cars and cause very rough idling and the engine light to come on. The coils are a bit tricky to remove (friction fit so you sort of have to wiggle them off the spark plug). If a coil has failed then the corresponding spark plug will be oily.
Coils are £25 a go, if yours are original then just replace all four as the newer ones are more reliable than the pre 2006 ones.
Not sure why the car is burning lots of oil, my FSI uses maybe a litre or so in 10,000 miles (ie between changes). Could be a serious problem?
Other problems with FSI's are Nox sensors, part for this is c£160 but easy to fit.
Ideally you need to find someone with VAGCOM scan software and get the fault codes read. If you are anywhere near Leeds I can do this for you FOC.
Posted : 26/04/2012 4:24 pm
If it's worn piston rings it could affect compression and hence idling, and cause oil to be burned.
However you would expect to see smoke if it were that bad. Or more likely smell it. I had a car that used a similar amount of oil (or perhaps even less) and it stank of burning oil. I got rid of it because I was embarassed as much as anything else. In traffic jams people in convertibles would be coughing and gagging at the fumes.
How come? You mean oily, or just black and sooty?
Yes Doctor, very unreliable of you!
I am around this weekend but in Winchester and haven't really got time to come over to Brighton unfortunately.
Are you about Wednesday or Friday next week?
DAVE
Posted : 26/04/2012 4:26 pm
 CHB
No they look oily (like a west yorkshire cafe spatula) as there is no combustion in the affected cylinder if the coilpack goes. Each cylinder has its own coil. The FSI runs at very high compression ratios compared with "normal" engines.
They are great engines, but a little high tech for many. My A2 gives 50mpg and goes like stink for a "girls car".
Posted : 26/04/2012 4:30 pm
Ok so there's no combustion - why does that make it oily?
(not challenging, just curious)
Posted : 26/04/2012 4:36 pm
the coil's a bit of a red herring.
if the coils are knackered there will be combustion problems but they won't cause oil to get into the cylinders in the first place.
Posted : 26/04/2012 4:38 pm
The manual for my 1.4tsi says that it can eat up to 1L of oil per 1000km/600miles. Apparently that's normal!
edit: although it doesn't actually use anywhere near that much.
Posted : 26/04/2012 4:58 pm
 luke
I was just about to post the same thing up to a 1l every 1000k on some of the audi engine's I assume this would go through the VAG group.
Posted : 26/04/2012 5:05 pm
Yes, I am familiar with the VAG group's engines liking for oil. I have a 1.8Tsi and travel with a bottle of the relevant oil in the boot. Goes through about 500ml every 4 months ( so every 4k miles ). Doing slightly better than was suggested it would when I bought it new.
Posted : 26/04/2012 6:18 pm
I wonder why.
Posted : 26/04/2012 6:33 pm
they burn less if you use the recommended oil
but there still thirsty
as for running rough could be anything from a leaky hose ,coil pack etc
if no engine warning light on ...
its mechanical with the exception of coil pack and spark plugs
disconnect the airflow meter an see if its any better
also check hoses for splits of leaks
Posted : 26/04/2012 6:35 pm
I'd start with basics and have a compression check done. You will then know if the rings/valves (poss head gasket) are buggered and can progress to jobs that will cost you money if that is all ok.
k.i.s.s. never assume..
Posted : 26/04/2012 7:10 pm
 CHB
DrP: you said you are using a "tank" of oil every 700miles. How much is this? Do you mean a litre?
Molgrips: reason that the sparkplugs look greasy if there is no combustion is because they get covered in petrol, but it never burns/ignites. So I (assume) that it sort of evaporates off due to the engine temp, but leave behind any of the heavier fractions of oil.
Posted : 26/04/2012 10:25 pm
Compression testers are available in Halfords btw - easier on a petrol afaik because I think you just remove the plugs.
CHB - I suppose a greasy sheen.. I thought you were talking about thick black gunk as if oil was in the chamber.
Posted : 26/04/2012 10:32 pm
 CHB
Greasy sheen indeed, just like the aforementioned cafe spatula. 😆
Posted : 26/04/2012 10:46 pm
 DrP
Well, took the coil packs off but my specific socket set isn't specific enough....... wouldn't reach the plugs!
Oh well - will see what the locals can provide!
DrP
Posted : 27/04/2012 11:28 am
You need a plug socket - available from Halfords.
Posted : 27/04/2012 11:52 am
My Golf TDI did this due to a cracked sump.
Posted : 27/04/2012 12:03 pm
My Mk 2 GTI did this due to valve stem seals. But it was pretty obvious as I practically disapeared when standing for long in traffic...
Posted : 27/04/2012 12:11 pm
 DrP
Ok, quick update as there's been useful info posted so far.
Took it to the garage (ages ago!) and they ran full diagnostics - nil wrong there. They did do a compression test which was LOW in 2 cylinders, but normal on a retest.
I think, as does the mechanic, that it's a know problem of vag fsi engines of the inlet valves getting coked up :-/
At the garage we gave it a treatment with wynns injector cleaner spray, and I've got myself another twin pack to do at home.
I don't think this explains the oil guzzling, but I'm sure it's the cause of the rough drive.
Ideally I'd like to use an endoscope to look into the inlets, as removing the head will be timely = pricey!!
So, anyone down south fancy cracking my head off.....??!!
DrP
Posted : 12/07/2012 9:25 pm
If the valves are coking up they won't be seating properly. Also, this can easily damage the valve seats as the deposits between the valves and the seats hammer into the tolerances a bit. I had a brand new pair of aircooled VW heads set up with the valves too tight and this happened to them.... It also made it smoke, which DOES explain oil usage. Remember the valve guides are lubed by oil, and a poorly seated valve will therefore let oil through.
To fix it I had to have the heads off (engine out job in a Camper) and regrind the valve seats on my new heads. I can tell you that regrinding valves by hand gives some amazing blisters.
Personally, I doubt very much of some wonder additive will make the slightest difference. Remember that thousands of explosions in the cylinder aren't shifting it....
My guess is that you'll be taking the head off to fix it properly in the end, if it is the valves coking up. Personally I'd worry that it'll damage the head too much to repair of not fixed in time.
What would I do? I'd get shot of the car, to be honest.
Posted : 12/07/2012 9:42 pm
 DrP
Cheers Pete,
Out of "diagnostic interest" I'll see what it's like after a valve decoke (either DIY if I can find a decent guide, or garage). It's a shame as all other aspects of the car are fine...
Will hunt online for a sensible guide to removing the head.....
DrP
Posted : 13/07/2012 6:45 am
Put thicker oil in it or check the grade in there isn't too thin.
To use that much it is probably burning it, as you've not said there is a lake of oil on your path or "mayo" in the coolant system
Not a mechanic but guess the only way that happens is through the pistons rings.
Then sell it.
To be fair, I put oil in a car years ago that was too thin. It p155ed through it. I put thicker oil in and it was fine for years.
Posted : 13/07/2012 6:51 am
Mail me with where you are?
Posted : 13/07/2012 7:04 am
 CHB
Pete, what you say about cylinder explosions moving crud is correct for most engines. However the fsi engines have "dry" intake meaning that fuel is added post compression, rather than on the induction cycle of the cylinder.
This means the intake valves never get washed with fuel. So add cheap 95 ron fuel that these are not designed for, and lots of short trips and you get problems.
Mitsubishi GDI engines have a similar problem....they need good fuel and long trips regularly to keep em sweet.
Posted : 13/07/2012 7:07 am
 DrP
Mail sent, Boobs....
I'm hunting the web high and low for Info on getting to the valves, but am struggling!
Anyone with a PDF on engine servicing at all?
Will also post on briskoda.
DrP
Posted : 13/07/2012 7:32 am
