Need opinions (&...
[Closed] Need opinions (& help) -> Gore Jackets?
[#3613360]
am looking to replace my winter Jacket (Endura Stealth) with a new one, been recommended Gore by a few people, but still unsure.
my stealth has been great but as per the majority of Endura products, is starting to fall to pieces at the seams. :S I've ridden in this jacket with just a merino base layer underneath in -5, and base layer+ LS top in last winter's freeze, was warm enough.
so the question is what Gore jacket to move to? been looking at the Tool as its fleece lined with a vent under arm zips too, also like the look of the Alp-X SO, but not sure whether it'll be warm enough..
WHYG?
cheers in advance 🙂
Posted : 27/01/2012 2:06 am
I've done aaalll the research last year believe me.
Gore phantom 2 if you can still find one. best cycling thing I've bought apart from my bike. Well worth the money imo and I'm a pikey cheapskate. I'm using it with a breathable base layer and a merino jumper when it is proper cold and I'm warm enough. with just the merino I can go anywhere at the mo. with a long sleeve thin base layer I'm fine for the worst of autumn/spring. approaching/leaving "summer" I take the sleeves off. It's versatile. It's ace.
Posted : 27/01/2012 2:32 am
Ive had a stealth , Tool and a Cosmo and whilst these jackets are/look toasty warm. I find them to be too much so ive just purchased the Alp X SO.
These type of jackets are more flexable by just adjusting your base layer/layers.
You end up with a jacket you can wear all year, and of course take the arms off the Alp X and you have a windproof gilet, which is a brilliant garment to have in your kit.
Nice liitle review from Ed @ Great Rock [url= http://www.great-rock.co.uk/2012/01/gore-alp-x-so-soft-shell/ ]here[/url]
They do size up small TG Store has a good size guide im a 40" chest and usualy a L in Gore but went up to XL
Got mine from Primera using a code on the home page around 30% discount came in @ around £122.
Hope that helps
Posted : 27/01/2012 5:37 am
+1 for the gore phantom 2 got mine as a Christmas present from Mrs Rockape and it's fab. I've been very warm lately when out night riding or just a Sunday blast. Like most things it's getting the layers right. It may feel cool before you get started but once you start to warm its snug. 😀
Posted : 27/01/2012 7:08 am
+1 Phantom however it's not as warm as the Stealth (the Stealth isn't as breathable), I can only wear my Stealth below freezing but the Phantom is good from +10ish to -5c (although I wear a second layer underneath when it's sub-zero).
Posted : 27/01/2012 8:28 am
I've been using a Phantom for the last year and would recommend it.
It's a great Winter jacket and I've used it done to about -8c with a merino long sleeve base layer and a jersey underneath. On milder days just a short sleeve jersey is fine under it.
It's not waterproof but I've been caught in showers or used it in drizzle and it's kept me dry.
Posted : 27/01/2012 8:49 am
 Haze
I had a Phantom for Christmas too, plenty warm enough on my 2 road rides with just a medium long sleeve base layer underneath.
It's been relatively mild but I don't think I need much more if/when the temperatures drop, probably just a heavier base layer or something.
Posted : 27/01/2012 10:01 am
 br
I've both a Stealth and a Phantom, and when it cold and wet/snowy I use the Stealth - otherwise the Phantom. Two totally different jackets.
[i]my Stealth has been great but as per the majority of Endura products, is starting to fall to pieces at the seams.[/i]
A bit harsh, but then I'd probably worn my Stealth 100 times always with a Camelbak - anyway, I took my original Stealth into my LBS (where I bought it from) and asked if they could send it back to Endura to see if they could stick down the tapes/seams. The Owner laughed as it was in a real state, but said no probs. he'd pass it on to the Rep. as he would be in later in the week.
tbh The best I was hoping for was a decent discount on new one, but a couple of weeks later I got a call to say my new Stealth was waiting for me!
So top call to Endura.
And the Phantom is really 'next-to-skin', so ought to be a tight fit with only/maximum a base-layer - plus the zip-off sleeves make it good for Spring/Autumn.
Posted : 27/01/2012 10:35 am
Talk to Endura;
[url= http://singletrackworld.com/forum/topic/thumbs-up-for-endura-customer-service ]http://singletrackworld.com/forum/topic/thumbs-up-for-endura-customer-service[/url]
I've got a Gore Tool and it's a lot fleecier than the Stealth so it can be a bit warm in the spring/autumn when the Stealth is still perfectly wearable.
Posted : 27/01/2012 10:39 am
I've got an original Phantom Plus which is excellent, just wear next to skin, but it only has one zip pocket which is a bit annoying. Got an Oxygen which is pretty good, slightly warmer than either of my Assos 851s, but obviously sweatier if it's mild.
Posted : 27/01/2012 10:48 am
 jfeb
I've had a Phantom and an Oxygen SO. Very similar. Oxygen SO doesn't have the zip off sleeves and is a snugger fit which I prefer. Wear the Oxygen SO without anything underneath between 5 and 15 degrees, -5 to 5 degrees with a base layer.
Posted : 27/01/2012 11:21 am
Firstly you have to decide whether you want waterproof or softshell. Then how hot/cold do you run.
Whilst the zip-off sleeves sound a great idea, you are still left with a sweaty back so a specific gilet makes more sense. Gore do a very good Windstopper one with a mesh back.
Currently you can get 15% off and if you enter the following code another 15% so 30% discount which is pretty good!
www.tgstore.eu
LOYALCUST2012
Posted : 27/01/2012 12:04 pm
Got myself a Gore Cosmo at the start of winter and the couple of times it has been cold enough to use it have remained toasty warm.
Recommended.
Posted : 27/01/2012 12:13 pm
