I have a Yeti Big Top, bit like this one, that I have to admit to modifying more than I ride. Shameful I know. Was set up single speed with front suspension but I hankered after a lighter ride.
A few years back I had an Ibis Tranny set up as rigid, s/s 69er; it weighed next to nothing and rode great but the slot machine had a habit of working loose.
Chasing the Tranny experience 😳 I got some rigid exotic monocoque forks off eBay this week, fitted to the Big Top tonight and it seems mint, ready for all the winter slop.
Now I’m considering drop bars, hoods etc but the outlay is a bit off-putting (especially as I don’t really ride the bike anyway). Before you slate me I do commute by bike and would like to try the Big Top, but its a 35 mile round trip and I’m not sure s/s would work.
Anyhow what about monster cross – I realise I’m 6-10 years late to the party?
Love my Monstercross, 2.2 tyres, flared drops and currently set up single speed and is a great laugh to ride and surprisingly capable. I’ve used it for anything from light touring on the GR5 (geared)through to ssuk last year.
did an “organised” ( 😆 ?) gravelgrind ride last year and the guy handing out the cue sheets was recording bike types and his list with stats from previous events showed majority monstercross rather than CX or gravelracer
Defining monstercross = can of worms. Given up trying to define it, for me it’s somewhere between 40mm and 2.0. And why do we change measurement scales between road and mountain?
Just been out for a 2 hour blast on my Genesis Vagabond. Probably 65/35% road to off-road. Kind of ride I would previously have done on my MTB, but comfier and quicker on the Vaga.
I’ve upped the front tyre to a 2.4, so I get the fast rolling benefits of the 2.1 WTB rear, but a bit more shock absorption up front. I’ve also stuck an old 100mm drop X-Fusion HiLo on it with under saddle lever. Makes the trail sections more fun 🙂
Here is the finished article – maiden voyage today went well – 25 miles on BW’s, canal towpaths and a little bit of road. Think I have finally found the Yeti’s best configuration for me.
Exotic fork
Hylex brakes
Cow chipper bars
Position is great – drops are excellent for climbing and when it gets bumpy.
I stuck some flared drops on my 29er singlespeed but it just felt a bit too stretched out. I probably should have tried a shorter stem on it. So it’s back to flat bars with stubby bar ends for yanking it up steep stuff.
But… I put the flared drops on my cx and upped the tyres to 38mm and it rides like a totally different bike. It’s not monstercross but the flared drops make a massive difference on the nadgery sections.
I may get another pair and give it another go on the 29er with a short stem.
Thanks for the comments – and thanks for the bars Charlie. The combination of drops and s/s seemed perfect for my ‘mild’ local off road and gravel. Climbing in particular benefited from the new position. I was immediately at home with the Cowchipper’s.
love this look for commuting did you use cable disc or fluid
Brakes are hydro’s – 160 rotors F&R. Worked well and quiet too. Did not realise that the Hylex came with rotors which made them decent value.
But it’s a bit too clean.
Came back filthy yesterday. But its sparkling again now 😀
My stem was very short as you can see, although there is also 25mm of layback on the seat post. The front end is reasonably high which helps too.
You’d have been far happier with a second hand Gryphon of course
