Log burning stove- ...
[Closed] Log burning stove- ideas
 hora
[#5509457]
Basically is it possible to convert a fireplace cheapily, are 'cheaper' stoves a false-economy (don't last) etc.
How much should I budget?
I'm starting this from a total newbie-perspective.
Posted : 12/09/2013 10:09 am
I will watch this with interest, as I have a very nice stove in my main room, but am considering a second for the front room - but as it would be used a good deal less, need not be as nice as the stove in the main.
Posted : 12/09/2013 10:10 am
Depends on how much you're going to diy and what needs doing to the existing Chimney.
Posted : 12/09/2013 10:20 am
Yes it is but you will get shouted down by those who want a "professional" job. Done half a dozen for myself and the family have done even more.
Depends on how cheap you want. Machine Mart stoves work fine. I would guess that in 25 years time they might not but doubt they have been around that long. I do suspect that if you need a big one quality may be more important.
Much easier in an old house though.
Posted : 12/09/2013 10:21 am
 hora
Noted on machinemart- ta.
I can do alot of the work myself. The only bits I can't do is lining the chimney? and re plastering around.
Posted : 12/09/2013 10:26 am
We where quoted £1500 all in to have a log burner installed. That included the flu, hearth etc.
When you re-plaster:
1 - Use a heatproof plaster and paint in the fireplace behind the stove or it will crack like hell.
2 - Chip off the plaster for a good distance (a metre or more) around the fireplace before making good because if you don't, the expansion of the new plaster around the hot stove will cause stress cracks to appear all along the join between old and new plaster. Guess how I know this?
Posted : 12/09/2013 10:45 am
 hora
Ah! Cheers 🙂
£1500 is a bit steep- what did the quote involve/did it include (their) sourced stove?
Posted : 12/09/2013 10:49 am
Included everything, stove, flu, hearth, cleaning out the existing fire place and, well, everything it needed.
I didn't think it sounded a lot?
Posted : 12/09/2013 10:51 am
Ymmv - it obviously does but heat proof plaster yes - final skim was gyproc prolite and just plain magnolia. And in the fireplace is just plain old pure brilliant white.
How ever i have a gert chunk of oak and an eco fan shielding the heat from the stove 🙂
And 1500 is a bargain for all that imo although dependant on stove used. .
Posted : 12/09/2013 10:53 am
I would have assumed DIY
Posted : 12/09/2013 10:56 am
 core
Just be aware the flue may (probably) need lining, and the installation of a woodburner is subject to Building Regulations control, so you either need to use a HETAS registered installer or submit an application to your Local Authority.
Also, since 2010 you need to install a carbon monoxide room detector in the same room as the appliance.
DIY/dodgy woodburner installations account for a large percentage of domestic fires through the winter, I have friends who are retained fire fighters who regularly attend chimney fires caused by poor installations.
Posted : 12/09/2013 11:04 am
£1500 for all that IME is cheap - it cost £930 to have just my chimney lined and the liner fitted to my stove (by far the cheapest quote I had!) - for a 2 storey circa 1905 house with a relatively straight chimney.
It's messy, potentially dangerous and legally certifiable work - hence the cost, I suspect.
Worth it though.. 😉
I got a cheapish stove though - despite my fitter's protestations.
Me to fitter: okay, so it's a high quality Chinese-made stove, what fundamentally is the difference with this Swedish one that costs twice as much
Him: Essentially, nothing. But it's just better.
(On reflection and after a year of use, I think I can see his point)
It's a bit like buying a Boardman over an Ibis. It works okay, but you know it could be so much more... nicerer
Posted : 12/09/2013 11:11 am
 hora
True/agree.
I'd be opening up the fireplace slightly (I'd previously put a piece of chipboard over and nailed a mdf fire-surround around), removing the 'cheeks' that were eitherside of the gasfire that was in there (all piping already safely removed.
See below, the inner edge is the edge of the fireplace brick aperture ('cheeks' are inside that to be knocked out). Shouldn't be too hard- I demolished a huge 70's brick/slate/mortar monstrosity around it to get to that!
Posted : 12/09/2013 11:12 am
£1500 is a great price all in defo.
Hora, the expensive bit is if you have to/decide to line the chimney.
See old threads on here re lining or not.
Paid just over a grand for fitting of lining, cowl & register plate.
If the bricks in fireplace are ok condition just re-point them as I did.
Posted : 12/09/2013 11:16 am
I have done them myslef it not exactly rockert science
Stove at the bottom flue through your chimney and attach- depending on age you may not even need a flue pipe depending on smoke test results.
Observe some rules on gaps and the like and ta dah its done.
Cheap stoves will eventually warp [ is steel] and /or crack if cast iron IMHO-Cast iron is generally better and dearer IMHO This may take years/decade to occur so your choice so I would probably get a good quality second hand one myself
Plastering almost always cracks near a fire anyway so i would avoid it personally and leave exposed brick but that is a personal choice.
i would get it signed off as well but its really not that hard to do
Posted : 12/09/2013 11:17 am
I've been quoted £150 for fitting inc pipe & plate. £500 if it needs lining. That's in Brighouse by my chimney sweep.
I do agree though that its not the most technical job, barring lining the chimney so can't see what is wrong with DIYing it if you have the time.
Posted : 12/09/2013 11:39 am
Our Stovax Stockton is 4 years old and perfect. Anybody tried a Mendip? I reckon you get what you pay for..
Posted : 12/09/2013 11:40 am
I've got two stoves, one I installed myself but with no flue liner (external chimney which is not 'very' old - may fit one at a later date) and another fitted by a pro (internal flue which I had lined).
The latter cost about £1000 for the liner and fitting (which was rather involved as it's an insert stove and required the old fireback removing and other bits and pieces) and I was happy with that.
My suggestions are:
1) Buy a good quality used stove off eBay and do it up yourself with new paint/seals/bricks and glass. I've done this three times and it's really dead easy.
2) If you're putting a liner in, make sure it's a good quality one as you don't want to be doing it all over again in 5 years time - the cheap ones do not last as long as they say they do.
3) Steer clear of cheap stoves. You may initially save a couple of hundred quid but if it's constantly sooting up/hard to start you're going to be mightily pi$$ed off in 6 months time.
There is also a question mark over smokeless coal and flue liners as well. My installer has seen many liners destroyed by the chemicals in smokeless coal in as little as two or three years.
Posted : 12/09/2013 11:45 am
 hora
Apologies for the thick question, how can you test if it needs lining?
There used to be proper fireplaces in our house (on the floor above you could see the outline of the small fireplace surround in the upstairs fireplace wall!.
I'm just worried that someone with a vested interest will say' yep you you do/when its already lined (or doesn't need it) then pocket the cash.
Any independent tests(ers?)
Quite a [url= http://thegreenlivingforum.net/forum/viewforum.php?f=21&sid=4624bb798901b453a8ece9b337e14e34 ]good forum over there[/url] for info.
Posted : 12/09/2013 11:47 am
I'd take your £1500 quote in a heartbeat... I've been quoted over twice as much to remove this gas job and fit a stove.
[img] [/img][/url]
Bloke did reckon it would take over a week and involve much faffage with skips due to the amount of fill that has been used to build up the fireplace to this, and the house is three story so much flue required.
I'll not be getting it done this year 🙁
Posted : 12/09/2013 11:55 am
We've been quoted £300 to move the pipe which is pretty much the same as installing a new pipe. That said the pipe isn't enclosed in a flue or chimney in the living room and is only boxed in in the bedroom upstairs.
Posted : 12/09/2013 12:02 pm
£1500 is really cheap to install a stove. We paid £2600 to go from this:
[URL= http://i1276.photobucket.com/albums/y477/BigBlackShed/BigPileOfRubble_zps1af26375.jp g" target="_blank">http://i1276.photobucket.com/albums/y477/BigBlackShed/BigPileOfRubble_zps1af26375.jp g"/> [/IMG][/URL]
To this:
[URL= http://i1276.photobucket.com/albums/y477/BigBlackShed/FinishedStove_zps12e3145c.jp g" target="_blank">http://i1276.photobucket.com/albums/y477/BigBlackShed/FinishedStove_zps12e3145c.jp g"/> [/IMG][/URL]
The stove was £1500 though.
Posted : 12/09/2013 12:19 pm
Does a modern(ish) clay pipe chimney need lining?
Posted : 12/09/2013 1:03 pm
I had our fitted last winter. £2002 all in. Stove was ~£700 of that.
Posted : 12/09/2013 1:06 pm
hora - Member
Open up the fire place, and chuck in a smoke bomb.. See where the smoke emerges.. If nowhere but the top, you're laughing..
Posted : 12/09/2013 1:12 pm
wasnt there a thread on here last year where someones neighbour fitted a burner without a liner and filled their house up with smoke.
Posted : 12/09/2013 1:14 pm
 hora
Are you serious?
There isn't something that will kill you involved.
Posted : 12/09/2013 1:15 pm
Can anyone tell me what makes stoves so special that when removing a fireplace thats been in use for the last 50 years that we need to line it ? - unless reducing to a uniform id so that airflow speed is kept the same.
Posted : 12/09/2013 1:38 pm
While we're on the subject, I've just had a Back boiler removed do you think I could use the Back boiler Flue on a wood burning stove?
[img] http://i.imgur.com/5Qyr2N1.jp g" target="_blank">http://i.imgur.com/5Qyr2N1.jp g"/> [/img]
Could save me a few pennies?
Posted : 12/09/2013 1:43 pm
Posted : 12/09/2013 1:47 pm
Lining a chimney will allow the fire to burn more efficiently (apparently). Hora, if you need a reccommendation, look up Fired Up stoves. Based near Greetland but they do work all over the place. They're good guys though so no bodge jobs - might pay a bit more for the privelege but at risk of carbon monoxide etc seeping into your house, its money well spent.
Posted : 12/09/2013 1:50 pm
More efficiently than what ? A collander for a chimney ?
Posted : 12/09/2013 2:03 pm
We've been pricing up converting from gas fire to an logburning stove in the livingroom.
Ours would involve decomissioning the gas fire, cutting out a propper fireplace (currently it's a raised plinth), lay hearth, beam over, supply & instal fire, plaster. For that we're looking at about £2k of which the stove itself is about £1k (ESSE, made in Barlick, just around the corner from Hope)
Would be about another £500 if we need to put a liner in too.
Posted : 12/09/2013 2:05 pm
No you can't - way too thin.
Posted : 12/09/2013 2:08 pm
We lined ours as otherwise you need to use a clay liner adapter and I've been told by two independent sources that it generally doesn't end well (basically your can get tar running down into your fireplace.
TR - In an open fire 80% of the heat goes up the chimney which gets nice and warm/hot so the gasses flow OK. With a stove it's only 20% of the heat that goes up the chimney (the rest going into the room) so it's doesn't get as warm and the gasses don't flow upwards as well as they did before. This means that the nasty gasses condense on the chimney lining and erode it.
Installing a liner serves two purposes:
1) it provides a smooth(ish) surface that heats up readily to enable the gasses to move easier which in turn means the fire burns better due to increased draught and there's less deposits in the flue.
2) it protects the existing chimney lining (which could already be damaged and leaking) from damage by the gasses.
Posted : 12/09/2013 2:11 pm
First stove I fitted was a machine mart job - Worked fine. Hearth was a couple of slabs of slate 'borrowed' from the waste tips in wales. As far as I am aware, the fumes leaking from the 'unlined' chimney never killed anyone. Cost - £500 ish.
Posted : 12/09/2013 2:12 pm
As far as I am aware, the fumes leaking from the 'unlined' chimney never killed anyone yet - and luckily I've not had a chimney fire
FTFY.
Please note you can still get chimney fires in lined flues if they're not cleaned.
Posted : 12/09/2013 2:17 pm
I dont believe in luck Sharkbait. - Just swept the chimney
Posted : 12/09/2013 2:19 pm
That was what one of my freinds found when he had a stove installed in his new extension. Brand-new chimney and hearth. He immediately had problems with tarry residues dripping back into the stove and making a right mess.
He had the contractors back and got it lined.
The problem disappeared.
Posted : 12/09/2013 2:22 pm
 core
Don't forget also that any appliance rated over 5kW requires combustion air, (a permanently open air vent) and it's recommended for those under, unless your house is really draughty already.
Posted : 12/09/2013 3:32 pm
Has anyone got a wood burner in a new build that doesn't have a chimney?
I like the convenience of newer houses but wouldn't mind a wood burner and would be interested to know how it compares cost wise
Posted : 12/09/2013 4:36 pm
captain slow, you can get twin wall flue installed to 'add' a chimney. my inlaws have done this for a burner, it works as well as any existing chimney.
the twinwall stuff can be put either outside or inside - outside being the cheaper option. indoors is possible, but will cost more as you have to poke it through floors and the roof - when done you can box this stuff in (i.e. where it runs through a room).
IIRC the inlaws was ~ 1.5k for the twin wall including install (plus stove costs on top).
Posted : 12/09/2013 4:51 pm
Check with HETAS but I think you have to leave any flue joints accessible for inspection these days, so can't just box it in unless you leave inspection doors in the boxing in.
Back boiler flue will be "gas vent" which is class 2 liner - you need Class 1 type liner for solid fuel burners and/or condensing boilers.
Posted : 12/09/2013 5:25 pm
Page 1 / 3
