Fox 36 Talas to Van...
[Closed] Fox 36 Talas to Van conversion
[#3733627]
Hi,
has anyone converted a 2011 Fox 36 Talas RLC to a Fox 36 Van? Am I right in thinking this would give me Rebound, Lock-out, Compression and Pre-load options? Will this setup improve small bump performance over my current SKF sealed (non Kash) fork?
cheers,
Crundi
Posted : 02/03/2012 4:09 pm
(just read it back - sorry for all the questions)
Posted : 02/03/2012 4:11 pm
Can't do it (different csu).Well you can but it'll cost you more than a new fork.
Posted : 02/03/2012 4:49 pm
Just spoke to Mojo, they can do it for £100 parts plus £100 labour. They said if I "convert the fork to vanilla you won't be able to return to a Talas/Float system without changing the CSU because the spring will mark the surface inside".
Anyone done this?
Posted : 02/03/2012 5:31 pm
I sit corrected 😀
Posted : 02/03/2012 5:34 pm
I'm wondering, if the CSU gets 'marked' will it start creaking, I've read a few posts from other Fox 36 users complaining about it.
Posted : 02/03/2012 5:54 pm
... Is this something I could be doing myself or is it a job for MoJo/TF Tuned only?
Posted : 06/03/2012 4:23 pm
 LoCo
Yes you can do it yourself if you're competent mechanic, I can supply you parts or carry the work out for you too, cheaper than you've been quoted 😀
Mail me for further details
Posted : 06/03/2012 4:25 pm
 cb
Why not sell and buy what you want - surely the Van is cheaper to buy?
Posted : 06/03/2012 4:33 pm
Fair point [b]cb[/b], although my lowers are in white and thats not common for a set of Vans.
Quote me happy Loco!!!
Posted : 06/03/2012 4:38 pm
As Loco said, its straight forward. The kit is really just a plunger, spring and pre-load cap. Make sure u de-pressurise your TALAS cart before removing it. I converted my 36 TALAS's a few years ago to VANs, one of the best things I ever did. It improved small bump and overall performance no end.
Posted : 06/03/2012 4:40 pm
Thanks Lang2jones. I've replaced seals and lower leg oil, but thats as far as I've gone with taking the fork apart. I read that I need a special tool to decompress the 'cart' and a different 'buffer' for the spring? Is it really just straight forward?
Posted : 06/03/2012 4:54 pm
I think the newer version of TALAS did not have a IFP in the 'cart', so u do not have de-pressure it. If you do have to, its no real different to just letting air out of your forks. I converted my in about 30 mins. Tools I used from memory were a socket set for the pre-load cap, a spanner for lower leg bolt, and a screw driver to let air out and fit plunger. From memory there is a circlip as well. Have a search on MTBR, for instructions if needed. A few people have done it before, or if not send them to LOCO etc. I'm about 11 stone and went for the medium spring.
Posted : 06/03/2012 5:17 pm
