Changing Trains Bet...
[Closed] Changing Trains Between Kings Cross & St Pancras
[#1086315]
After some sensible advice please. My daughter is having to travel down from Cambridge into Kings Cross & then picking up another train from the St Pancras to the Kent coast (via Ebbsfleet so I guess its probably the Eurostar platform). The only thing she is not sure of is this changeover. The British Rail route planner is telling her its a 31minute walk between the two stations but in truth it only looks like you need to cross the road. Would very much appreciate a bit of realism from someone who knows.
Posted : 30/11/2009 10:19 am
Stoopid double post
Posted : 30/11/2009 10:22 am
the map is right - it is a 5 minute walk at most. just out the door by platform 8 and across the road - very easy to find and do.
the british rail route planner often throws up odd journeys - I wanted to look up a train from enfield to finsbury park (a 20 minute direct journey at the most) - except if I had followed the journey planner I would have had a train to stevenage, then to perterborough then direct to FP - quite bizarre
Posted : 30/11/2009 10:23 am
They are pretty much one station. 15-20 mins should be plenty of time to change trains IF they are on time!
Posted : 30/11/2009 10:24 am
The planner seems to assume that you're walking with a zimmer frame and weighed down with 50kg of bags. The two are about 200m apart - just add some time to get out of one and into the other, St Pancras especially can be a bit of a trek from the front door to the platform.
Posted : 30/11/2009 10:31 am
what simon_G said. 10 minutes should be ample, but then I wouldn't want
less time than that if I didn't know the set up.
Posted : 30/11/2009 10:41 am
Thanks Guys
Posted : 30/11/2009 10:53 am
Yep, pretty much one station these days. A couple of minutes easy walk.
Posted : 30/11/2009 11:03 am
To be honest, its only 31 minutes if you have two broken ankles and are juggling all your items as you were too poor to afford a suitace.
Posted : 30/11/2009 1:24 pm
