CCDB Air/BOS Vip�...
[Closed] CCDB Air/BOS Vip'r
[#3710958]
Tempted by a new shock for the SPicy - my RP2 needs a service as there's nitrogen in the air... had decided to get it Kashima coated, then started looking at maybe trading to the RP23, and then.... so, basically, I've got the money spent in my head.
ANyone recommend one or the other of these?
Posted : 24/02/2012 3:27 pm
CCDB Air not yet on these shores. Due very soon at TF Tuned.
If it's as good as the coil it will be really very good indeed.
Posted : 24/02/2012 4:10 pm
There's nitrogen in the air? You wanna get that changed ASAP, it might explode or something.
Posted : 24/02/2012 4:14 pm
CCDB Air is here and on sale, AFAIK
Isn't air 78% Nitrogen anyway? 😉
Posted : 24/02/2012 4:25 pm
Heh. Nitrogen in the oil, or somesuch. Whatever's causing the odd, slurpy sucking noise.
Posted : 24/02/2012 4:30 pm
The gas (be that Air, or just Nitrogen which is what is in there) has got mixed up so much with the oil its *cavitated.
Just get it serviced, it will be fine.
If you really want to spend money on a new one they speak to someone like Loco for advice. But your existing shock will be fine once serviced.
*Cavitation is the formation and then immediate implosion of cavities in a liquid – i.e. small liquid-free zones ("bubbles") – that are the consequence of forces acting upon the liquid. It usually occurs when a liquid is subjected to rapid changes of pressure that cause the formation of cavities where the pressure is relatively low.
Posted : 24/02/2012 4:41 pm
He used to be a dive guide you know 😆
Posted : 24/02/2012 4:55 pm
Apparently 🙂
Posted : 24/02/2012 5:29 pm
Exrauk told me no DBairs until end march (£505 rrp)
i am not sure what the weight is either vs CCDB.
Posted : 29/02/2012 12:44 am
£505 rrp 😯
Posted : 29/02/2012 12:47 am
Weight is ~550g. Near enough the same as a CCDB Coil, minus the spring.
For 500 quid i'm sure if you get one you'll convince yourself it's 117% better than your old air shock, and it's transformed you into Nico Vouilloz.
In reality, once the honeymoon period is over you will probably be no faster with it, just £500 worse off albeit with a shiny new shock on your bike.
I'd just get your current shock serviced and tuned for you, and spend the £400 you save on a week in the Alps. If you really want one though, i'd buy the CCDB so you don't have to go through the pain of trying to deal with BOS/R53.
Posted : 29/02/2012 7:49 am
I quite fancy a Monarch Plus RC3, but I'll probably settle with getting my RP2 Pushed instead.
And I'm sure that it'll be more than capable of handling my mincing.
Posted : 29/02/2012 10:35 am
 Rik
Not really my CCDB is 405g without the spring and only 630g with spring and all the mounting hardware.
Posted : 29/02/2012 11:00 am
Hob Nob - Member
I could service, tune and kashima coat the current shock, but I doubt it would be as good as a CCDB, and would cost plenty. Tempted mainly by a bit of extra climbing traction, and yes, the shiny newness.
Posted : 29/02/2012 11:13 am
Obviously size dependant. Mine was 100g more, plus a bigger spring = more weight.
Of course, but you're in the justification to yourself stage of want/need. By the sounds of things, your shock needs a service, and it may as well have a tune whilst it's in bits. Anything above that is want justification. A well tuned half decent shock for you (like the Fox RP series) should be plenty good enough, using the Vouilloz example again, he hasn't got any slower now he's off the BOS kit & on Fox...
However, if you want it, buy it!
Posted : 29/02/2012 11:14 am
 Rik
Mines only a 400w spring which helps too
Posted : 29/02/2012 11:18 am
Get it serviced and buy a second hand coil.
Posted : 29/02/2012 11:22 am
