Alfine Hubs
[Closed] Alfine Hubs
[#1247868]
Just had a search through the forum and can't find a thread asking for opinions please.
Further to my post the other day re a 1x9 setup this is another consideration for the Scandal build.
Are they any good / reliable as I believe they were designed for commuter bikes?
Is the weight noticeable?
What ratios do you run?
Anyone running 32f x 23r with a Nexus sproket?
Anyone using them for marathon events - solos etc
Thanks in advance
Posted : 22/01/2010 12:14 pm
The Nexus hub was designed for commuters, the Alfine is the MTB version of it. There were a couple of threads on here when the snow was about praising their lack of clogging. Might be worth a search.
Posted : 22/01/2010 12:24 pm
[URL= http://www.singletrackworld.com/forum/topic/problems-with-my-alfine-in-deep-snow ]Have a look here[/url]
Posted : 22/01/2010 12:27 pm
generally mine has had most use as a commuter along muddy canal tracks, but i did do MM2009 with no problems at all (29er alfined slot dropout scandal)
running a nexus sprocket (either 18 or 20) to get a better chainline
[img] ?ver=12641596480001[/img]
[img] ?ver=12641593650001[/img]
compared to a SS, then yes the weight is noticeable - just depends if you really care about it
Posted : 22/01/2010 12:28 pm
Good timing. I used mine at the strathpuffer.
[i]Are they any good / reliable as I believe they were designed for commuter bikes?[/i]
only had mine 3 months but no reliability issues and very few / none reported. I spoke to Ben @ kinetics who sells a few - he has seen no failures even with them being used on tandems.
the nexus is the commuter hub. The alfine is rated for MTBs
[i]Is the weight noticeable?[/i]
to me - when you pick the bike up yes. In riding - no. I can bunny hop it as badly as I can any bike. Teh overall weigh increase is not much - its the distribution that is very different
[i]What ratios do you run?[/i]
32 / 18 as stock. I ran 22 / 18 at the puffer. Going to 32 / 16 for commuting
[i]Anyone running 32f x 23r with a Nexus sproket?[/i]
It has been done and should be no problem. IIRC thats the lowest recommended gearing
[i]Anyone using them for marathon events - solos etc
[/i]
Quite a few alfines at the puffer - mainly on Genesis IO IDs like mine. Used as hire bikes a lot - the Hub at GT uses them and are on their second batch. I ain't a real racer tho.
Posted : 22/01/2010 12:31 pm
Yep I am on a 29er. No problems with it.
Well apart from the fact that I'm not that keen on it performance wise.
Posted : 22/01/2010 12:39 pm
Had one on my 29er set up for commuting-34/18 with the sprocket turned round for better chainline (remove the guide).No problems reliability wise,you have off back off a LOT to change gear and its not so much the overall weight but the fact its hung right off the back of the bike.You cant flick the back end over stuff too easily-a few people who got them suffered loads of pinch flats till they adjusted.
Posted : 22/01/2010 12:51 pm
Thanks everyone for the feedback.
Probably a numpty question, but Jeremy, when you say you ran 22x18 do you mean you did 22 (f) & 18 (r)
If so, what crankset are you running and how did you do it. From my understanding, if I was to do this with an XT crankset, I would have to run the 22 ring in the granny position. Does this not screw up the chainline?
Is this easier than doing the 32 x23 thing I mentioned above, which you do remember correctly, is the recommended lowest combination?
Is it easy to change the sprocket?
Posted : 22/01/2010 1:02 pm
For sitting spinning your way through long rides Alfines are brill. But for point and squirt, dodging the trees in the woods riding they don't have the crisp pickup of a singlespeed. That's why I have two rear wheels for that bike and can swap them and fit the shifter in 15 minutes or so.
Posted : 22/01/2010 1:23 pm
hi
yes 22 front 18 rear. 22 on the granny ring position. Chainline that few mm out but I used a 9 spd chain and no issues. You can reverse the dished rear sprocket to get perfect chainline
Raceface crankset
32 / 23 would be better - you can get perfect chainline easily and 22/ 18 is ridiculously low. Think granny 1-9 with a conventional set up - I was spinning out at 15 mph or less. Being old and slow and riding the puffer I wanted really low gears.
changing the sprocket is fairly easy. remove the shifter mechanism - which just unclips and remove a big circlip and the sprocket just comes off.
Posted : 22/01/2010 1:29 pm
Thanks. This sounds like exactly what I'm looking for. Bike is being built for 24 hr solos. Like you I need to be able to have quite a bit of flexibility over gearing.
I'm built for comfort rather than speed but I go for ages... He he
Posted : 22/01/2010 1:42 pm
The beauty of the alfine for the 24 hr solos is that you have no mech to break or go out of alignment - faff free riding.
Posted : 22/01/2010 1:47 pm
I've had mine about four months now and think it's great - I got fed up with skipping gears and chainsuck during the muddy months! I use it to convert my SS for winter use. I've had no problems so far. I iniatally ran 32/16 but have now changed it to 32/18 which is much better in the claggy conditions. A mate runs a Scandal 29er with 32/23 and is very pleased with it. I don't really notice the weight when riding it, but it does feel heavy when you pick it up.
Posted : 22/01/2010 1:57 pm
Mrs F's slot dropout InBred has had one since late 2007, ridden most days sometimes on sometimes off road, and it's been flawless. We had it serviced by the very good LBS summer 09, but having taken it to pieces they said it didn't need it, just regreased, put back together and charged next to nothing.
As other people have said, yes when you pick the bike up, and the weight is all at the back, but it's not a big deal riding it. I'd have one instead of my 1x9 derailleur Summer Season if I had a frame and the money.
Mrs F runs 32/18 happily, but a friend who rides mostly on road has just swapped to 32/16 with a Nexus cog, and I think is going to want 34 or 36 at the front.
Posted : 22/01/2010 2:23 pm
The Alfine will outlive several derailleur drivetrains if you like riding in typical UK mucky conditions.
Posted : 22/01/2010 2:33 pm
I love mine. Very reliable and apart from a quick cable tension adjust I haven't touched it. I run an 18 on the back and 26/36 upfront with an alfine tensioner and a 9spd chain.
Posted : 22/01/2010 3:29 pm
How easy is it to service the alfine?
(Just had a few people with nexus hubs breaking from winter commutes!)
Some say expensive or difficult to do?
Posted : 22/01/2010 3:37 pm
I like mine. But it is weighty. I notice it on dips. The back wheel seems to 'suck' into the ground. Also the weight is postioned out the back which moves the centre of gravity back. I countered this with a set of Fox 36's.
[url] http://www.singletrackworld.com/forum/topic/bike-pictures-from-today [/url]
And you can see the weight difference between my Alfine'd and Geared HT's. The forks and tyres are a few pounds heavier on the Alfine'd bike but the other components are similar in weight. There's still an 8lbs difference in weight.
Posted : 22/01/2010 3:47 pm
Servicing is easy. Strip the gubbins out of the shell ( a few circlips and stuff) and the gear cluster comes out. It is then soaked in oil, drained and reassembled.
NO way is an alfine 8lbs heavier. I would guestimate that compared to a 1x9 its a lb or two heavier
Posted : 22/01/2010 3:55 pm
has anyone tried a gearbox bike with an Alfine, similar to the GBoxx idea with the Rolhoff?
Posted : 22/01/2010 4:05 pm
 Del
rockitman,
try searching again. as an example:
[url]= http://www.singletrackworld.com/forum/search.php?search=alfine+inbred&advanced=1&exact=1&posts=1&highlight=1&users=0&located=0&forums []=0&maxcount=100&age=999999&direction=0&sort=date[/url]
Posted : 22/01/2010 4:06 pm
TandemJeremy - Member
If the derailleur system was built to the same life expectancy as the Alfine it would weigh much more.
Posted : 22/01/2010 5:00 pm
Thanks for info TJ.
Haven't stripped an Alfine model yet.
Posted : 22/01/2010 5:04 pm
I've tried a Hammerschmidt/Alfine combo... it feels (and is) quite heavy, but the gear range is good and I didn't mind the slight drag when the front is in 'overdrive' ('big ring' equivalent). Have dropped the Alfine for now to save some weight and am running a single 16T on the back... so a 2-speed setup 🙂
Posted : 22/01/2010 5:05 pm
If you read the whole sentence you'll see that I qualified the heavier items between the bikes.
I was surprised by the difference. The forks and tyres may account for 4.5lbs. The component spec difference is at most a 1lbs but the rest is the Alfine.
Posted : 22/01/2010 5:41 pm
Either that's really badly worded or your scales are really bad.
So your trying to say the alfine weighs 5-6lb?
My whole bike is 32lb (minus 1/4 ounce) and the only light thing on there is the RC41F. THe rest is all clysedale to go with the rider, you'd have to be getting a heavyweight FS to beat mine. When riding I don't notice any weight penatly anywhere.
Edit - Ah you qualified yourself. So your saying the alfine weighs about 3.5lb... which is what it weighs... then the shifters and cables would cancel out. Your 8lb statement was very misleading.
Posted : 22/01/2010 6:18 pm
 mboy
cough* Who's the sad git that weighed his Alfine hub before building it up into a wheel to go on his bike *cough...
ME! 😆
Mine was 1668g unadorned. Which is what, just over 3.5lb iirc...
Weight difference between a derrailleur system and Alfine setup... Hmmm... Well, if you're running full XTR I think you'd probably gain 2lb or more, but if it's Deore or SLX, or even XT kit you're running, you're only going to gain 1 to 1.5lb overall.
Noticable? In a dead lift of the bike yes... When out riding? Really, it is only very slightly noticable that all that weight is in one place. Certainly my bike doesn't feel that rear heavy that it's unbalanced when its wheels leave the ground or anything.
Gear ratio wise, I was running 32x20 on my 29er, but have just bought a 22T Nexus sprocket and had a 34T chainring lying about so they've both gone on. This will only lower the gearing very slightly, approx 3% overall, but I'm hoping it will suit me. The 32x20 on a 29er at least (10% larger rolling radius on the wheels) was just slightly too tall for me... I may even end up dropping a tooth on the front perhaps and fitting a 33T ring, but the 34T is what I had lying about and the 32T ring that came off was way past its throw away date...
If you want an Alfine gearing calculator Spreadsheet that I knocked up (this applies to anyone), then email me (email is in my profile)... It's all singing, all dancing etc, and will tell you all about your overall ratios, gain ratios, gear inches, mph etc in all of the gears and for any wheel size and gearing combination.
And performance wise, well only done maybe a dozen rides on mine so far, so not quite as well placed to comment as some, but not had a single issue yet. Yes, it's a bit slower under shifting to an easier gear than a derrailleur setup (you have to back off slightly), but otherwise it's great. With my current gearing my 1st gear is the equivalent to a 22x27 derrailleur setup, and my top gear is equivalent to 32x12. So I can climb most hills without getting off and walking, and I only spin out above 20mph on the road in top.
Personally, I can't recommend them highly enough. I know a few people with them now, and everybody raves about them. It's pretty much a case of singlespeed simplicity, but with the added bonus of 8 gears rather than one. Sure, it's a bit heavier, but if you're not racing will that matter? In fact, speaking of racing, there's a guy in the US that posts on MTBR forum a lot that to prove a point, took his Alfined 29er out on one XC race instead of his normal race bike. He won funnily enough!
Oh, and the Alfine is/was a godsend through the snow and the mud. Haven't washed my bike once since I got it (about 2 months ago), gave it a mild brush down yesterday just to get the worst of the crap off prior to fitting different sprockets and a new chain. Everything just works! I was getting fed up of spending nearly as much time cleaning the drivetrains on my other bikes as I was riding them through the mud, I gave the Alfine a go. Now I doubt any of my other bikes will get a look in until the ground firms up somewhat!
Posted : 23/01/2010 4:35 pm
I've had mine on for a bit over a year now - on a Scandal. No probs at all.
Did the Kielder 100 on it and it was submerged at least three times but still absolutely fine. The advantage of being able to change gear without pedalling is surprisingly useful, especially when on a course like that when it's hard to anticipate sudden changes in direction/gradient.
I've not noticed the weight but then the Scandal was very light to begin with. The gear ratios are a bit more spread out than a derailleur, more like 8 singlespeeds slung together so that's how I ride it. I've got 34/20 which suits me fine on a 29er.
Posted : 23/01/2010 4:52 pm
 Spud
How much are you looking at for an Alfine set-up?
Posted : 23/01/2010 5:20 pm
£200 or a bit more depending.
Posted : 23/01/2010 5:22 pm
 mboy
Hub is currently £154 at CRC, cheapest I've seen
Shifter is £27 from CRC
Cog is £5-8, shop around
Fitting kit generally £10
So about £200, plus the cost of a rim, spokes and getting the wheel built...
Or hang around on ebay looking for a bargain, you may or may not be lucky. Have seen a whole setup (including built wheel) for for as little as £125, or as much as £225 on ebay...
Posted : 23/01/2010 7:55 pm
Another question - What kind of chain / chainrings do you run? Do your run singlespeed chains? Do you need a chain tensioner if not slot dropout?
Thanks
Posted : 25/01/2010 9:59 am
I am running unramped chainrings and a nine speed chain - purely so that I can use the same sram links and keep everything compatible with my other bikes. Singlespeed chain might be better considered in isolation. You need some method of adjusting the chain, EBB, slot dropouts or a tensioner
Posted : 25/01/2010 11:13 am
rode one yesterday on a fifty k loop on a scandal 29er borrowed from a mate and i thought it was awful, very clunky, having to back off the power loads when trying to climb and the gear ratio's weren't right for me.
i'll be sticking with a regular mech , casette, shifters, etc.
my mates bike has gripshift which i also found really uncomfortable, can you run a normal trigger shifter?
Posted : 25/01/2010 11:49 am
Yes you can run a rapidfire shifter, Alfine is usually supplied this way. I reckon he was running a Nexus shifter on his bike.
Posted : 25/01/2010 11:57 am
correct, he's using a nexus shifter
Posted : 25/01/2010 12:16 pm
Would that be why it was so clunky?
Posted : 25/01/2010 12:32 pm
no the shifter worked fine but it was just really uncomfortable for me(i feel like i have rsi a day later in my thumb and wrist, which is why i was asking about rapidfire shifters), it was the hub itself that gave the cluncky feel and sound when changing gear ratio.
to me, i felt it was just a poormans rohloff, which i accept there is around a £1000 difference.
Posted : 25/01/2010 12:38 pm
Out on interest exactly how much abuse would you think an Alfine capable of withstanding.
Fed up on having no working gears on my DH bike...
Posted : 25/01/2010 12:42 pm
If we dare ask what's the conclusion of the 'premier' only comparison between the Alfine and Rolly?
http://www.singletrackworld.com/2010/01/alfine-vs-rohloff-premier-content/
Posted : 25/01/2010 12:44 pm
Anyone know of someone in the Manchester area who might let me have a quick blast on one (5 minutes)? I was completely sold on the idea but Flatfish's comments have concerned me. Really don't want to drop £200 on one and then not like it and have to get the whole wheel rebuilt and buy a Hope hub!
Posted : 25/01/2010 12:49 pm
i'm not tryin to put you off but i'm reviewing it from a outsiders point of view, you know how it is, nobody will ever admit they bought a dog of a bike/car/hub/etc.
all i'm saying is it's not for me so i'll stick with regular gears which i admit get clogged with mud and wear a lot quicker.
Posted : 25/01/2010 12:58 pm
I can understand flatfishes concerns - For me the advantages outweigh the disadvantages for some types of riding. for a 24 hr enduro bike for a non racer such as me they are great. The fixed chainline / chain centres and lack of maintenance / missed shifts outweigh the slightly sluggish shif tand th3 non even gear spread.
If you buy one and don't like it they have a high resale value.
Posted : 25/01/2010 1:08 pm
 mboy
Regarding the issue with the hub not liking to change to an easier gear under load... You quickly adapt a better technique, changing to an easier gear slightly before you need it. Anyone remember 10-15 years ago before derailleur setups were quite so advanced and would readily shift gear under load? We all had to back off to enable them to shift then... Wouldn't say it's an issue at all personally, I just look a bit further down the terrain and assess what gear I'm likely to need before I come to a climb/obstacle. The massive benefit of being able to shift gears when stationary, should you say get stuck on a climb and have to restart, is ace though!
The spread of gears is a little wide if you're used to a 9spd cassette. It's not horrendous though. Most gears are fairly well spaced, there are 2 quite big jumps though. These being between 1st and 2nd gears, and again between 5th and 6th. Personally I don't find this an issue. With the gearing that I've got on my bike, the 5th to 6th jump is fairly irrelevant, because I'm generally only using 6th 7th and 8th gears either on road or on anything pointing downwards. So I'm getting some gravity or terrain related assistance. 2nd to 5th are well spaced, and it's these gears I use most of the time offroad. The 1st to 2nd jump isn't massive though, only slightly more pronounced than going from 1st to 2nd on "normal" 11-32T cassette. No real biggie, first is primarily a bail out gear anyway, so the fact it's a lot easier is actually a positive for many.
Best way to think about it is like this... Are you the kind of rider that regularly uses all 27 gears on his MTB and values having a gear to keep the correct cadence for every situation and doesn't mind a fair bit of maintenance to keep everything working just so in the British Mud? Or are you the kind of rider that has questioned the need for a big ring on his MTB (or possibly already removed it), and also rarely uses the largest cog on the cassette on his current bike, and is fed up with maintaining a derailleur system in the British Mud?
If you're the former, don't bother, Alfine will not be for you... If like many of us you're the latter, an Alfine is quite probably going to seriously impress you. People have said to "think of it as a SingleSpeed with 8 gears" rather than think like it's a geared bike. Not sure if this is true or not, as I do actually still tend to change gear quite a bit on mine. But I've had a couple of DH bikes in the past, with a single 36 or 28T chainring up front, and an 11-32T cassette out back, and used to amaze myself how much I could actually ride if forced to get out of the saddle and honk a bit more when it came to the climbs. So a single ring with only 8/9 gears is quite "normal" for me anyway... The fact that one of my bikes has a full 27 speed setup is only because that's the one that gets used if I know that the ride will involve a combination of very steep climbs and/or lots of on-road sections where I will benefit a lot from the higher gearing. Rest of the time I make do with 2 rings and a bash, or a single ring.
Oh and as TJ says, they have a high resale value and are always in demand. Don't like it once you've tried it, you won't lose much money selling it on...
Posted : 25/01/2010 1:44 pm
Thanks Maverick Boy. I think I'll give one a whirl.
I very rarely use the big chainring, however I do use the largest cog on the cassette, but I think sometimes that just psycological. I could always adjust the gearing though to suit. The other thing is I only ride full suss bikes at the moment, both of which are "sit down and pedal" bikes (Yeti & Commencal). This will be for a Scandal build and if my memory serves me correctly you can get out of the saddle a bit more on a hardtail.
The more I think about it the less the shifting will be a problem. I grew up on a late 80's Rockhopper. As you said, you selected your gear before the climb and then accepted you weren't going to be able to change without backing off. I do change gear a lot nowadays though. But said by previous poster - it's 8 singlespeeds, shouldn't take much getting used to.
I'm building the bike primarily for a couple of solos later in the year. I won't be "racing" so to speak, just plodding around in circles for 24 hours. Potential of ripping the mech off / getting continually caked in mud etc is far worse than not so slick shifting.
Right, that will do it then. Alfine here we come... Now, what wheels do we need?
Posted : 25/01/2010 2:24 pm
Page 1 / 3
