My home wifi network has worked almost flawlessly for ten years or more. I’ve a BT home hub…a couple of generations old now, wifi switched off and an Apple AirPort Extreme router (which I bought many years ago sencond hand off Ebay) with an Apple Airport Express extender. I moved to this set as the BT router kept on dropping out and the Airport router was the only one at the time with dual band. All been fine all these years, but recently on the iMac (all OK on tablets and smartphones) I get an issue where the iMac will work perfectly fine for a few minutes or so after turning on, then will cease to load up new page…so I’ll navigate to another site and the progress bar will load to about 25% then freeze and hang. The machine hasn’t crashed or anything and still works so definitely an internet/wifi thing. Also same thing happens even if I don’t navigate away from a website..it just ceases to function. But all is fine on smart devices and tablets.
After a bit of Google-foo’ing and trial and error the only thing that seems to get it working again are the following steps:-
1. close down safari
2. go to ‘Network’ in ‘Systems Preferences’
3. Go to the Proxies tab and untick the SOCKS proxy box
4. Go to the DCHP tab and renew the DCHP licence and apply
5. re-open Safari and all is well again until I next turn off and boot up again.
Though a combination of my google-foo’ing and trial and error stumbled across the above process which works 100%, I’ve struggled to find out why it works and what’s ‘wrong’ and what I need to do to fix it.
Part of me thinks maybe the Apple Airport setup is now way past its best and since Apple no longer make Wifi routers or support the ones they’ve made I’ve just pressed the button on an new Mesh setup, so I’ll look forward to seeing if that helps, but even if it does I’ll still be interested in understanding more about what I’m actually doing when I carry out the steps above and why it works and what I need to do to do a proper fix (assuming it isn’t as simple as the old Apple routers).
Thanks.
