So I’m STILL having issues with one of our showers… The flow out the shower head is a dribble…
But another shower on the same floor is fine… Both are fed by a gravity/hot tank system (the other side of the house is a combi, and is fine)
Sooooo…what I’ve done is :
Replace the water shut off valves that side of the house as they were aged and wouldn’t turn off
Used NEW working valves to shut off the hot and cold water.
Removed the shower in question, leaving just the 15mm pipe sticking out the wall.
Now this is the odd bit… When I turn the water valves back on, the water FLIES out of the wall…
I’ve measured the flow at 12L/Min. Not amazing, but not terrible.
Of course, flow does not equal pressure… but…
I thought the issue may be the shower has a diverted (to a rain head, or standard head) so swapped it with a single head unit. Same issue.
The only other cheap option is to try a simply, NO THERMOSTAT shower mixer.. Wickes has one for 60 quid, but oddly it’s vastly different fixings, so isn’t jsut a case of swapping.
Will this make a difference?? Can a thermostat component choke the flow a lot?
We’re getting quotes for a combi to be fitted but really wanna save this as a last resort.
I just can’t for the life of me figure why this ONE shower is crap!
The taps and bath in the same bathroom work fine!!!!
Thoughts on a postcard!
DrP
