Did a long gravel ride at weekend and near the end when in lowest 4 or 5 gears (big cogs) there was a noise like a dry bearing rumble soon as went into bigger gears disappeared.
i cleaned, degreased chain and derailleurs and re lubed. However same noise. What is strange is that it starts around 4 or 5 from biggest sprocket, if go up one more and then drop it back to original rumbling gear the sound disappears?
i have a giant revolt with GRX x 1 with a 11-42 rear.
Anyone have any experience thoughts or ideas before i start taking it all apart and probably failing to fins the cause?
