@Phil_H your issues sound like they could be due to nickel sulphide inclusions within the glazed panel. Very small pockets of gas within the glass which are affected by changes in temperature and the cracks propagate .
Toughened glass should go through a rigorous quality control check before it reaches the end user, however there is still a risk that imperfections could be present in a pane that has passed through this QC.
Most commercial /public facing toughened glass is also laminated, so if it fails due to inclusions then the pane often slumps within the frame and doesn’t fall out.
As for the OP, probably related to the recent sun and high temperatures . Possibly movement in the building due to the ground drying out. Putting stress on the frame.
