Home › Forums › Chat Forum › Where do I stand – bike shop damaged my bike
- This topic has 102 replies, 53 voices, and was last updated 7 months ago by bri-72.
TeedertodderFull Member
In a bit of a quandary. I took my new frame in to the nice guys at the local independent bike shop to have the BB threads chased-through pre-build. Standard practice.
Seems the sides were slightly out of line and they’ve stripped the non-drive side…
They can get a BB which screws together, but they’re expensive (my cost implied) and I’ve a new one at home that is now not needed. And a new frame that is now permanently damaged (although potentially was a QC fail at the factory? Who knows)
I don’t wish to fall out with the shop, but what do I do?
Ta
26EwanFree MemberThey’ve written the frame off haven’t they? Id expect a new frame.
the-muffin-manFull MemberThis is what they (should) have liability insurance for. I’d be well peaved and would want the frame replacing.
Some half-cock bottom bracket is going to cost you more whilever you own the frame.
4mashrFull MemberThey ****ed it, they fix it. There were already threads cut into the frame, so it’s been proven that it can be done.
I’m struggling to get my head around how they’ve managed to strip threads when they were supposed to be cutting them
3AidyFree MemberI’d expect a replacement frame. Even if they’d shell out (pun intended) themselves for a screw together bottom bracket, that’d make any future replacements really annoying and possibly limit crankset choices. Also I’d find it heartbreaking to live with a brand new frame that had a bodge to start with.
airventFree MemberIt should be replaced at their cost. If they’re even slightly hesitant at that it would be the last time id use that place as I can’t even work out how they’d strip the threads when chasing them.
willyboyFree MemberA well known frame builders damaged my frame after respraying it. It was an Alloy Colnago with fluted tubing, and they managed to crush the top tube fluting slightly.
I got a new frame from them.
3trail_ratFree Memberas I can’t even work out how they’d strip the threads when chasing them.
I can, especially if they have a high quality(sharp) tap and duff threads to start.
TeedertodderFull MemberHmm unlikely I’ll get a new frame as it’s a nukeproof…and yes it will feel a bit bodged (although the Enduro bearings version would be ok possibly) which is gutting long-term.
I don’t want to fall out with the shop, and hate conflict/bad feelings. The irony is that I’ve spent the past 7yrs on a bike with pressfit BB and not had any bother at all…and that’s with me fitting them.
Cheers for the support, let’s see what happens. I’ve just applied the invisiframe stuff too🤦🏼
12AidyFree MemberI don’t want to fall out with the shop
Um, because of the wonderful service they give you where they ruin a new frame and then expect you to pay for a workaround for the problem?
EwanFree MemberYeah sod that. They will have liability insurance, if they’re professional it doesn’t need to be an unpleasant discussion. They should want to keep you as a customer. If they can’t get a new frame they should pay you the value of the frame. Even that is a bit rubbish as I guess you got the nukeproof at a massive discount in the firesale so you’d not be able to get an equivalent. If they mess about this is what small claims court is good for.
2dovebikerFull MemberI’d expect the shop to put you right – if the solution is an expensive screw-together BB, then they can supply and install one at their cost. If they don’t agree, then they can supply you with a replacement frame at their cost.
AidyFree Memberif the solution is an expensive screw-together BB, then they can supply and install one at their cost.
If I were willing to entertain a screw together bottom bracket, I’d want that, and some compensation on top.
TiRedFull MemberJust replaced a Miche BB with a Shimano in my alloy Dolan. I cannot tell you how many times I checked the alignment of the NDS before ramping up the torque. Even slightly amis and those threads are toast. If you don’t love the frame, I’d take their fix. But resale the frame is now worthless. Of course the same is true of the manufacturer.
1nukeFull Membernukeproof
Could be replaceable if its one of the ones that’s on the cheap list that the ex crc chap is selling as per this thread?
(Skip to page 45)
2DougDFull MemberThey can’t be that nice if they’re not sorting something out for you.
1EdukatorFree MemberAll may not be lost, I’ve salvaged BB threads that others (including manufacturers) have **** with a pair of these:
Clean out any bits off sticking out tube that may get in the way with a grinder. Check the faces are perpendicular and parallel, and correct with a file. Then insert the tool and proceed slowly and carefully checking with a set square as you go.
I there’s not enough metal left add braze which obviously will end up with a partial repaint.
But if it’s new and they’ve **** it they should replace it.
1PoopscoopFull MemberThere are only two lbs around here and I’ve had bad experiences with them both. The positive has been that it made me get (almost) all the tools and experience I need to fix my own bikes over the years.
I’m like you op, hate conflict and try to avoid it all all costs but even I wouldn’t be happy with them damaging a frame and expecting you to bail them out.
Id be pressing them to make good the damage at their cost as a minimum and never go back to them again. Not due to the damage as such (these things can happen) but trying to shift the cost onto you. That’s not on and id never give them my money again.
Hope you get it resolved either way mate 👍
AidyFree MemberAll may not be lost, I’ve salvaged BB threads that others (including manufacturers) have **** with a pair of these
Telling us what they’re called might help us google for them
2Phil_HFull MemberDepending on the amount & type of material around the bb shell they might be able to ream & sleeve it.
Scroll down to thread repairs.
1EdukatorFree MemberTarauds de boiter de pédalier Eldi. 😉
Which I Googled and got this:
The pair are probably more than our OP’s frame cost.
AidyFree MemberI’m trying to work out how they’re better than a normal tap set. Does the extended section centre it better in the shell?
6anderzzFree MemberSorry what is this you had done?
Every bike I’ve built I’ve just took the frame out of the box and screwed a bottom bracket into it. (or pressed if push fit).
Surely they are shipped ready to be built?
PoopscoopFull Memberanderzz
Sorry what is this you had done?Every bike I’ve built I’ve just took the frame out of the box and screwed a bottom bracket into it. (or pressed if push fit).
Me too but I know that a lot of people consider it good practice to have this done before a build. Different strokes and all that…
1leffeboyFull MemberIs that tool not exactly what the shop used in the first place?
1AidyFree MemberYeah, I’ve never had to chase the threads of a brand new frame – or even most used frames. Maybe it was unnecessary, but it’s still the shops fault.
1tonFull MemberPraxis works BB that screws together inside the BB shell is a very good bit of kit.
i ran one in a surly trucker with a stripped BB shell, for about 4 years, no problem.
davidrFull MemberDo they not have a BB tap tool? If you’re in or around Exeter then I know at least one place that can help.
trail_ratFree MemberIs that tool not exactly what the shop used in the first place?
Given it’s a a taper tap . It should be – if they were following machining principals
Often though the shop will be too cheap to buy a taper tap set and will buy a considerably cheaper thread chaser which doesn’t have the lead in of a taper tap -which is fine for 90% of these kinds of jobs a shop will see – it’s meant for cleaning out swarf/corrosion/paint /nipped threads in a good thread form. If the threads misformed high chance you’ll only make it worse with a chaser
EdukatorFree MemberDoes the extended section centre it better in the shell?
Yes.
Some manufacturers send out perfect frames and some do not. I’ve never had to reach for taps when building up Look, Specialised, Giant, Lapierre… But some manufacturers send out frames that require work before they can be built up. And some manufacturers build up complete bikes with cross-threaded BBs among other horrors. The latest I’ve put right was a Brompton of my own. When I came to replace the BB I took the plastic cupped BB out (with difficulty) and found the aluminium-cupped BBUN72 wouldn’t go in because the drive side thread wasn’t in line. The above tool allowed me to correct it.
I had a policy of if it was fixable I fixed it before sale and only sent stuff back to distributors/manufacturers if it obviously wasn’t going to be fixable or the fix would degrade the product. It was easier, cheaper and faster than sending stuff back.
In the case of the OPs frame it could have been Nukeproof who cut duff threads or the lbs that buggered perfectly good threads trying to chase them.
1AidyFree MemberDo they not have a BB tap tool?
I mean, that’s presumably what they’ve used to chase the threads. I can’t think of another way a bike shop would do it. If you’ve somehow managed to completely misalign the tap, and then hamfistedly proceeded to crossthread it in, I think those threads are beyond saving.
1TeedertodderFull MemberThanks for all the comments.
Yes I always have BBs chased through on new frames as a precaution to problems down the line with poor alignment…and seems to have caught me out at the start which is a first for me. Usually have them faced too but on this occasion it wasn’t needed.
I’m not naming the shop as I genuinely believe this to be poor thread alignment and a frame made of chod. They have been apologetic and generally deal with high end kit and elite riders, so isn’t from lack of experience. Doesn’t give me much confidence in the rest of the frame though…
I don’t think I want another Nukeproof even if one was available, so the option is a praxis or equivalent BB, or try and find another Enduro frame that will fit the shock and the pile of new parts I’ve accumulated…
I’ll know more in the week, but does look like I’ll be riding on the old bike tomorrow (thank goodness I’ve still got it!)
EdukatorFree MemberAn example of a badly alligned thread it was impossible to screw a metal-cupped BBUN72 into:
I reckoned it could be corrected with the above tap without loss of strength so did so, it’s fine now.
Without too much loss of metal.
1bri-72Full MemberYou seem to be quick to assume the frame was the issue and the shop less so. But you’ve zero proof the frame was in way the problem.
Doesn’t need be a fall out with shop. Just have the chat with them making clear it was a brand new frame which they’ve responsibility for. Unless they can prove you or frame at fault (can’t see how they could) it’s their responsibility. No need to argue your only question is how are they going to sort you out.
4AidyFree MemberUnless they can prove you or frame at fault (can’t see how they could) it’s their responsibility.
If it was me, and it was a brand new frame, I’d be really dubious if there was any resistance at all putting the taps in. I’d stop and check after a couple of threads, not just keep on forcing it through.
EdukatorFree MemberYes, Aidy. It’s obvious really quickly if there’s something amiss. It’s then a question of how amiss and whether there will be enough thread left if you continue. If in doubt send it back rather than try and fail.
5labFree MemberIf you’re putting in a Shimano or sram crank, does it actually matter if the BB can be done up tight (assuming there’s no play when it’s mounted with the cranks)? The crank will stop it coming undone anyway.
dyna-tiFull MemberThe shop that caused the damage is under obligation to make good on their incompetence. Because even if they fit a push fit BB, the damage is still there and you’ll always be reminded of it.
Tell them straight to replace the frame or its small claims court.
