For forks, everyone loves Pikes but for most folks Revelations are a better buy, they’re not as strong but still strong enough unless you’re a maniac, and they’re a lot lighter. The last of the Revelation 426s came in a 140mm maxle model that was basically a lightweight Pike and is quite a good buy usually, the newer ones cost a little more but are lighter.
Rebuilding your old rims onto new hubs can work out pretty expensive… If you need to get it all done professionally, I’ve always found it cheaper to sell the old ones and buy new. Pro 2s are the default option really but the maxle axle is too weak, it needs a full thicnkess maxle to support it otherwise it’s fairly likely to snap. So none of those tapering maxle lites.
