Well given I’ve never done it before I should err on the side of caution, don’t you think that would be wise?
Yes, a bit of caution is wise, and some good advice was given by most. However some of these suggestions are bordering on the ridiculous, for what you have asked for help with.
I was laughing at the suggestions put forward, rather than your initial question.
You’ve asked the equivalent of which coil spring compressors to buy when swapping the shocks on my Passat and been sent to red bull F1 team HQ as that’s the right way to ensure your suspension will be perfect. When what you need is a simple solution for a relatively simple run of the mill job. Like you said the ground around you is hard as nails already. Dig a hole, and use the mix that’s printed on the back of the cement bag. 😀
