Looks like my Fat King front hub started to be noisy. Bearings after all river crossings and wet Peaks/Lakes rides finally giving up.
Quick check of Tune website manual for my hub tels me that to disassembe end caps, to get into bearings I need TT08.4 tool from the set below.
It looks like a bit of machined rod with pawl that is getting into notch inside of throughaxle sleeve.
Easy… But goddamn expensive 🙁 Whole set looks to be about 80 quis posted from Bikes24 or Bicycles Discout.de.
On top of that I do not really need whole set, as I’m only having one, front hub. And not planning to buy rear/any more any time soon…
Any word of wisdom on how to do it at home without wrecking whole thing out? Or maybe you know someone/you are that person that is owing whole set and can lend me 08.4 tool to strip my hub?
… or shall I just go full pelt, sell the hub with note “requires new bearings” and buy Hope instead? Wheel rebuild will be required for that one of course 🙁
IME no need for the special tools-I replaced all the rear bearings in my Kong rear hub using sockets as supports/press. Just go easy and Tune also recommend to use Loctite 641 to bond the bearings in-place. You may need the tuning shims to get the tolerances correct. I think Hope use the same bearings so you could use those (made by INA-FAG). I highly rate Tune hubs-now on my 2nd set of King/Kong’s.
One end-cap is fixed to the axle and the other is removable – slide in a small length of steel rod and at one end you’ll feel a lip of the end-cap – tap against the lip and the end-cap should gradually move off the axle and then come free.
