A319’s are a pinned rim, not welded, so you are likely to get leakage at the joint on the side walls which you can’t tape.
Firstly, most rims these days are pinned or sleeved. Since disk brakes there isn’t really much advantage to welding anymore as brake tracks don’t need to be flat. In strength terms it’s a non-issue because rims work in compression not tension. And welded or not are very weak under side loads.
Secondly, it’s not an issue, either
a) stans tape slightly wider than the rim so it rolls up the edge. It only needs to go high enough that the tyre bead rests on it to seal.
b) stans tape slightly narrower than the rim but with a layer of PVC electrical tape on top because its stretchy/flexible.
I prefer B because it means I only keep 1 roll of narrow tape that works over the spoke holes and make up the rest of the width with electrical tape (which is also lighter).
