- This topic has 13 replies, 4 voices, and was last updated 8 years ago by theflatboy.
tech geeks – hard drive bad blocks
Hey chaps, my NAS HD, 3 months after purchase, has 20 bad blocks. i’m currently in the process of backing up all the important stuff, i.e. photos and music from it.
Once done, what are my options? Is it sortable, or a return under Sale of Goods/Warranty job? Bad sounds bad, but how bad are we talking?!
Cheers people.
Posted 8 years agoWarranties vary between manufacturers, check. Might need a certain number of failures to be “faulty”; this used to be the case with old disks, dunno if that still applies. Could be up to a five year warranty on it, tho.
TBH though, either way I’d look to replacing it. It might last for years without further issue, but I’d wouldn’t trust it for anything important.
Posted 8 years agoMight be worth looking at the PassMark DiskCheckup software depending on what OS you’re using. That way you can get yourself that juicy juicy S.M.A.R.T. info to see if theres anything else the matter with the poor bugger 🙁
Posted 8 years agook thanks. i had a hunch i should replace, but what i’m unclear about is why/if i should have to fork out for a new one after three months? is this an error with the drive or would it be considered consumer liability? any ideas? 😕
and RRM, it’s in an ARM-based QNAP NAS.
Posted 8 years agoany more gems of insight, experts? 🙂
Posted 8 years agodo you have a desktop/caddy that you can attach it to?
Posted 8 years agoi do indeed – desktop with a spare bay, i believe.
Posted 8 years agowhack the drive in and get a gathering of whether there’s anything else wrong with it? Then you’ve got yourself a giant pair of nutcrackers when you go knocking on the suppliers door.
If you’re emailing remember you’ll be dealing with sales people who wont exactly know much about drives so you could baffle them with numbers/charts/dead sector counts 😈
Posted 8 years agospeedfan might give you enough info, just remember to run it as administrator 😉 think its shift right click or shift alt right click to get the extended options when you run it
Posted 8 years agook i will do that, cheers very much for the help. i’ll get some info on here once i get a chance to do it. 🙂
Posted 8 years agoTry and down load the data sheet. It will have all sorts of info like like temp ranges and other environmental operational factors. If should also have something like read write cycles, failure rates e.t.c. This could all be useful to be able to quote in writing your email.
Datasheet FTW!
Posted 8 years agoE.g. This one shows how many hour on average before failure and warranty info for different drives.
http://www.seagate.com/docs/pdf/datasheet/disc/ds_barracuda_7200_10.pdf
Posted 8 years agoAfter three months, I’d be taking it back to the supplier.
Posted 8 years agocheers all.
Posted 8 years ago
The topic ‘tech geeks – hard drive bad blocks’ is closed to new replies.
