Yup, fitted some recently to replace OEM pulleys that had shot bearings. Couldn’t get them working at all – constantly dropping the chain from the lower wheel despite endless fiddling. Ended up speaking to Superstar who agreed to take them back and replaced with a new set of OEM pulleys. Worked perfectly out of the box.
This drivetrain was worn to 0.75% (we’re re-running three old chains back through it before replacing the whole lot) and I wonder if it would have worked better with a brand new setup, but there’s no question that the OEM pulleys were far more tolerant and worked without fuss.
As a note, unlike Shimano pulleys (but consistently with nearly everything SRAM make), the bearings were shagged long before the teeth were worn out. They are cheaply and easily replaced on their own, so in future I would just replace the bearings for a few quid, rather than the whole jockey wheels for upwards of £35. For reference, I’ve never known a Shimano pulley with a worn out bearing – at least, not before the teeth are completely gone!
