It’s still there.
It’s had a massive soaking of release spray, for several days, I’ve tried hitting it very hard lots (and lots and lots) of times now it’s cooler in case the crank spindle had expanded in the heat, and I’ve tried hitting it back the other way to see if only one side is stuck and it would start to push out the bearing cups.
Nope.
Even resorted to removing the bearing seals and inners to see if I could start removing the bearings to remove the inner races. Not a chance.
I was going to give the bike a full refresh anyway so I’m now stripping it down, rear linkage has come off and it’ll get stripped to a bare front triangle, I’ll then be able to brace the frame properly against something while trying to hit it again. If not, I’ll be ringing round a couple of bike shops….
One thing is for sure, I ain’t fitting a 30mm crank on it again.
24mm hope press fit with the replaceable bearings and a matching crank.
