Rebuilding some old ebay cheapo Rebas and there is a serious amount of stiction. Done a full lower service and one of the bushings feels a bit rough. Previous life of these forks was as commuters and left on lockout so there was some corrosion to the stanchion surface at bushing level. I’ve cleaned the stanchions and polished them shiny (below the seals so will never see damage), but replacing the lowers there is serious resistance. Seals lubed, foam rings cleans and soaked in oil. Could it be bushings have corroded/expanded slightly?
Before I go and sand them down please offer words of wisdom. Want to run these forks short anyway as they’re going on a mess around/pump track build.
Stanchions did look slightly bowed in (2mm-ish) from crown end to axle end, although that could be a trick of the eye.
Thanks
Chris
