We don’t make Stanton’s headsets. They asked once and we made a load of samples but they went back to taiwan probably because they were slightly cheaper
The reason headset bearings rust out is they generally have bad sealing. I spent a fortune on several revisions of moulds to get our lip sealing right so we don’t appear to have any issues in the decade of selling them. We also have had bearings instock for the last decade too for quick and cheap refreshment
another issue is trapped water in frames. Once it’s in there it makes your frame a rustfest due to 100% humidity which keeps condensing on the cold steel till it rusts it
stainless bearings are stupid. They are too soft especially with the tiny ones on thin section bike stuff
if you can get the size then it’s almost certainly our type 1/2. Most common size out there.
neil SuperstarComponents
