Home Forums Bike Forum SRAM T TYPE and older AXS
Viewing 8 posts - 1 through 8 (of 8 total)
  • SRAM T TYPE and older AXS
  • binman
    My T type rear mech stopped working, can I stick the older version on temporarily or is there a comparability issue ?
    binman
    Compatibility…
    1
    DickBarton
    Assuming you have a udh and that allows the non-type t mech to fit them why not?
    1
    andylc
    There’s definitely a difference with the flat top chain and cassette and the slightly delayed shifting that somehow moves the chain perfectly into the next gear. Presumably the older AXS mech wouldn’t do this and shifting might be not quite so good??
    binman
    Thanks, the bike came with a UDH in the box of bits, so will give it a go.
    binman
    Have chucked it on and with some additional adjustments is functioning. The chain would ideally be shortened, but as I hope to have the T type back on next ride I will just avoid the smallest chain ring.
    That warning about not reusing the split link, they don’t really mean single use do they ?
    1
    hammerandcycle
    I’ve re used quick links multiple times and it’s never been an issue. Although officially they should only be used once.
    1
    andylc
    My Shimano supposedly single use quick link has been regularly removed for chain waxing for about 3-4 years. Personally as long as it still clicks in place I’m happy. If it gets loose I’ll replace it.
