Has anyone had an issue with Uber pads and SRAM Code R brakes and 200mm Centreline front rotor combo? This is on a Trek Slash. I havent changed the set up, only switching out the original pads for Uber Race.
Now that the front pad is nicely worn, I can see the rotor isnt quite reaching the top of the pad and has left a large ridge. The rotor is definitely 200m and the Post adaptor is +20mm, so that seems correct from Trek. The calliper is the direct mount type, it sits directly on the mount, so no issues there – ie it has accidentally been spaced out by washers.
It looks like a 203mm rotor would fit better, either that, or the Uber pads dont quite align the way they should. I’m going to put the original SRAM pads back in and see if a similar ridge appears. But just wondered if anyone else had had similar issues?
