Bleed again.
When I got mine they were a PITA to bleed, it only seemed to work if you followed the SRAM guide to the letter, and even then it took a second attempt. Do not be tempted to think “well this trick works on shimano / hope, I’ll try that”. If you don’t need them for a few days, wind the reach adjuster out, get a ziptie and clamp the lever reasonably tightly to compress any air bubbles and leave iv overnight for them to rise to the lever then try again.
Other possible fault is a sticky piston not sliding out properly, take the pads out, squeeze the lever a few times to pump them out a bit, then push back in gently one at a time, that should lubricate the seals and let them work properly.
