On the back of putting a hole in the 2.5″ DHF I’m running on the rear of my BFe, I ordered 2x approx. 2M of the 50mm rod a few days ago from Dortech.
One of the 2M lengths now resides in that wheel – a 26″ Flow Mk1 – and it fits perfectly. Just! The big volume tyre helps (wouldn’t want to try 50mm dia on a 2.3″ Maxxis), and the length is exactly right for 26″. Might need two shorter sections for 650b or 29″.
The tyre was a bit harder to get on, as the rod pushed the bead into the rim hooks, so a screwdriver was used as a tyre lever to get the last 15cm of bead on. The tyre inflated with a compressor with ease (it’s a non-TR DHF) and seems to have stayed up. It also feels somewhat like I guess a runflat does without any air in it.
It’ll get a run out in Chopwell on Sunday over some rocks and roots, but hoping it’ll be good. Since the Spitfire snapped I’ve been using my spare BFe and my riding style still isn’t acclimatised to hard tail riding just yet, and getting the air pressure in the rear tyre is more of a guess than knowing the exact number.
As for the fluid, I’m using Oko diluted about 50:50 with water for now, so hope it’ll still seal. However, if I was to repeat I’d cut channels out of the upper and lower edges of the rod, and possibly drill a lot of 10mm holes as well so that the fluid can migrate. In fact, I’ll be trying it on the HB160 when it eventually arrives!
