So far I’ve only done 22miles on her.
10mile road commute to work, with ~8laps of the local pumptrack.
12 mile night ride in the woods with ~2k ft of climbing.
First impressions were that the riding position is good and power delivery is good. But it’s definitely got some lateral flex.
It was a bit of a handful on the pumptrack, but knobbly tyres, soft suspension, and long reach aren’t going to be great.
I can also manage to get the tyre to buzz the disc-side chainstay if I push it hard into corners.
Looking super closely I think the rear wheel is slightly out of alignment (~1-2mm to the disc side by the BB). The good news is that the syntace dropouts have offset options that can allow for rear wheel alignment corrections! So I’ve ordered a 0.5mm offset one already.
The off-road night ride was a much better test.
I felt comfortable enough after the first climb and downhill section to just ride it the same speed as my old hardtail. I even hit all the jumps and berm gaps that I normally would first time. Also took it on the rough natural DH trails and it really rode well.
Climbing position is excellent, it does take a bit more effort to get the front wheel up. The only negative was that my weight wasn’t as much on the back wheel, so slippy roots took some concentrating to get traction right.
Good news is that I didn’t noticed the lateral flex much while riding it in the woods, I think it was once when a hitting very off-camber line.
Also I noticed some chain slap so I need to get some rubber on the chainstay quick, and maybe a strip on the downtube as did hear a couple of rock strikes.
All in, just tiny niggles.
