Hello,
I have been riding my an ss for years. I like to use a conventional hub so that I can put gears on it when i need to (vertical dropout, tensioner in place of the rear mech)
I have always just used a sprocket from an old 9 speed cassette, some old cassette spacers to pad it out and an old 9 speed chain, all has been good.
However, this was on some reasonably tough hubs, either a Chris King ISO or a Hope XC Ti, titanium blocks are fine.
I have a much lighter rear hub which I would like to use on the ss, a Tune Prince. The freewheel on this is incrediably light but also appears to be very, very soft. Using a thin 9 speed sprocket causes it to dig into the splines. It also has slightly odd splines, one thick one to guide where the cassette goes, and the rest thin, almost a reverse of a normal one.
Anyway, I am looking for a sinlgespeed sprocket which will fit a conventional hub but which will spread the load, I guess something which is nice and wide at the bottom, taking the space of two or three sprockets in a cassette if you see what I mean. If it is also available in many different sizes that would be good, looking for 19/20/21 at present, would also like to have 17/18 just in case ( I do change gear, it’s just a very manual shift…)
If it fits an old 9 speed chain then great, if I have to buy a proper singlespeed chain to fit this sprocket will that fit a Hope Narrow/Wide ring? The 9 speed chain fits that perfectly.
Cheers guys.
