chairing is not centred. All SSs will have it to some degree.
i dont know how you would solve it on a 3 piece crank. If the chainrings are attached to a spider with bolts as on a Hollow tech or something, you loosen all the bolts a little. Not completely. enough so that the chainring is staying still, but will shift when tugged on.
Then rotate the crank to a tight point, and squeeze the upper and lower chains together lightly to pull the chain ring towards the rear wheel. Rotate to find a tight spot, and repeat till its as uniform as you can get it.
Tighten the chainring bolts
retension the wheel.
as i say, dont know how your chainring is attached to the crank, but presumably there must be some for of adjustment there.
