I’ve got a pair of SK gravel Kings, mounted on vittoria elusion disc alloys, with about 4,500k on them.
Initially set up tubeless by the shop, they were running fine until over the last month I’ve (on separate occasions) put 3-5mm cuts on the shoulder of each tyre. When I did the first one I realised all the sealant had dried up, and whilst replacing that switched both valves for Milkit ones (so I could inject sealant – the ones supplied initially wouldn’t let the tube through) and the MilKit sealant. Both holes have been repaired (by me) with slugs/worms/bacon strips and I’ve managed a 120k ride on the repaired rear without issue.
I now cannot for the life of me get more than 20psi to stay in either wheel. They’ll sit quite happily at 45 on the stand, but 10 minutes into a ride they’re back down to 20. The air seems to be escaping very slowly from either the repairs or the valve.
Should I persevere with tubeless or go back to tubes? For the first 2,000k those tyres ran fine with tubes on a different set of rims, but I’d prefer to stay tubeless as (on my MTB at least) I have a predisposition towards pinch flats. There’s every chance that I’m just an inept mechanic, although I switched my MTB to tubeless myself last year and it’s been running perfectly.
All suggestions welcome!
Andy
