Home Forums Bike Forum shimano xt m8000 chainset…….is it 'boost'?
  • This topic has 6 replies, 3 voices, and was last updated 8 years ago by ton.
Viewing 7 posts - 1 through 7 (of 7 total)
  • shimano xt m8000 chainset…….is it 'boost'?
  • ton
    anyone know?
    chilled76
    Not unless it is specifically advertised as one. There are two. The normal m8000 and m8000 boost.
    ton
    and looking at mine……there is no way of telling if it is or not…. 😡
    otsdr
    Do you still have the box? (notice the FC-M8000-B checkmark)
    Also, should be on the crankarm itself:
    chilled76
    So long as you have chainstay clearance it doesn’t really matter, just means your chainring is 1.5mm further inboard.
    In all honesty I think a non boost chainset on a boost frame can actually improve chainline if you are running a dinner plate cassette as it lines it up more with the massive chainrings.
    otsdr
    You can always add spacers under the chainring on the Boost one, but you can’t avoid the chain rubbing on the rear tyre with the non-Boost :).
    ton
    just checked…..it is boost. thanks for the info gents.
The topic ‘shimano xt m8000 chainset…….is it 'boost'?’ is closed to new replies.
