My road/gravel bike currently has 50/34 on the front with a 11-34 on the rear. When it is on the turbo for zwifting it has an 11-28 cassette on it. The rear mech works fine swapping between the two without any adjustment (wheel off trainer so no need to swap).
I am looking to replace the crankset to give me a lower gear as I ride up some fairly steep climbs (for me anyway) and I can be left grinding the cranks round at 50-60 rpm in the 34-34 lowest gear.
So I am looking at replacing the tiagra crankset with a Shimano GRX crankset so going to 46-30 on the front. This would lower my gear inches from 26.3 to 23.3 at the lowest gear but would also change my upper end from 119 to 109.
For Zwift I don’t think this matters – I rarely use the 11 speed gear and I can just increase the trainer difficulty if I find I start spinning out. I should add that my natural cadence has gone from mid 70 to mid 90s so I am able to generate power across a much wider range and on the road the difference in the upper end is easily made up by the increased natural cadence.
Can anyone see any issues with this change? Will a Tiagra 2 speed front mech work fine with a GRX crank? The bottom bracket is the same so no issues from this side and the lower gearing will open up the climbs a bit and allow me to use the cadence that I now am able to sustain.
