@thepodge No idea really. I’m open to offers The whole bike has just gone up on ebay as they have an offer on this weekend, starting at £400
There is a right hand shifter, with hydraulic front brake, the control box thingy under the bars, external battery, lots of wires and connectors and things, shifter motor for the hub and the hub itself, built onto a Mavic Open Pro 700c wheel. The hub bearings could do with a service but the shifting bit is absolutely spot on Oh and a battery charger (which was £75 new!) And then all the other bits you need to make a bike… Turns out if you want to have a drop bar shifter, a hydraulic disc brake and a hub gear D12 is the only way to do it IIRC it cost just over a grand for the Di2 bits, plus the rest of the bike
There’s pictures and things here https://www.ebay.co.uk/itm/334137690620
If you are local you are more than welcome to come and have a play on it, I’m just south of Edinburgh, eastern end of the Tweed Valley Likewise OP, if you want to see one in action you are welcome to pop round.
