Home Forums Bike Forum Servicing Hope XC hubs
Viewing 8 posts - 1 through 8 (of 8 total)
  • Servicing Hope XC hubs
  • porcaro
    Is it easy to change the bearings on these hubs? And how much for the parts to do it?
    snaps
    Fairly straight foward, just remember that one bearing is retained by a circlip (difficult to see when covered in dirty grease) & the spacers have to be replaced in the right order or else the wheel will go tight when you do the QR up.
    Details here
    Bearings probably a tenner from your local bearing supplier.
    andrewh
    There’s a number on the bearings, can’t remember what it is off the top of my head, but have a look at yours and give your local bearing supplier that number.
    mattstreet
    And – top tip – if you can, take it apart it a bag, it’ll save you searching the garage floor for the pawl springs for half an hour after they’ve pinged out. Wish someone had told me that… 😀
    nbt
    Read and note
    http://mountainbikerides.co.uk/fettling/3-wheels/5-hope-xc-rear-hub-service.html
    Top tip – an old rotor bolt will fit nicely in the end of the axle and provides somehting you can **** with a hammer without damaging the axel. you will have to hit it a *LOT* harder thank you think to get it to move,
    nbt
    sorry, didnt spot that someone had posted the link. shows how usefult it is though!
    coatesy
    if not mentioned in the links, they’re 6001 2RS bearings, 4 of them.
    adam1330
    Did my rear bearings a couple of months ago, with help from this vid:
    I did put the new bearings in the freezer as well, which helped getting them back in.
The topic ‘Servicing Hope XC hubs’ is closed to new replies.
